For those of you with the auto, where are you senting your shift points, senting your rev limiter, and are you spraying through the shifts. Thanks, Greg.
You can set your shift points as your cam power band requirs, but its not good to shift while speaying. Use a window switch to cut of n2o 200 rpm before your shift point.
