Having trouble installing TNT LT1 kit
Old May 30, 2003 | 02:17 AM
snksknr94's Avatar
I cant seem to get the plate mounted between the throttle body and the manifold. The sensor on the bottom of the TB (IAC??) Hits the thermostat housing when the plate is in, so the bolts don't line up. I took the grinder the the TB a bit, and I'm gonna try to file the thermo. housing tomorrow, but did anybody else have this problem? Installing this kit has been a nightmare and I'm starting to think it's not even worth it anymore. I guess I'm just frustrated with all of it. Anybody have any suggestions???
Old May 30, 2003 | 03:43 AM
RUFFIDLNZ's Avatar
This is what I did. I took a dremel tool to the bottom of the throttle body (the piece that runs the coolant through not the actual throttle body). This was easy to do and gave me just enough clearance for the throttle body to clear with the plate in between and didnt do any harm to the piece that was dremeled.
Old May 30, 2003 | 07:46 AM
Dan Parker '96's Avatar
I did a light grind on the thermostat housing (cheaper to replace if something went wrong).
If you eyeball it correctly, it doesn't take much.
LeftoverChinese
Jan 14, 2024 03:03 PM
HectorM52
Jun 23, 2016 08:42 PM
CARiD
Jan 14, 2015 04:00 AM
Dec 4, 2014 11:56 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
