How do I install & wire a purge kit?
Old Jun 17, 2003 | 03:07 PM
snksknr94's Avatar
Question How do I install & wire a purge kit?
I got a TNT purge kit to go with my TNT kit but it didn't come with any instructions. I have it installed, just want to make sure I did it right, but I unsure how exactly to wire it. I have the T fitting it came with hooked between the main N20 line and the solenoid. Then I have the line coming off the the T going to the purge solenoid, then then the hard line coming out of the purge solenoid, which I'm 99.9% is correct. Now how do I wire it up??
Old Jun 18, 2003 | 12:44 PM
john97z28's Avatar
I just did mine a few weeks ago. Send one wire to a ground, I chose the same where my relay is located. The other wire is sent to the purge button. The other lead on the button is sent to a hot wire, I butt connected it to my activation switch. Now purge away!
Jan 23, 2015 01:13 PM
CARiD
Jan 14, 2015 04:00 AM
Dec 4, 2014 11:56 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
