Nitrious ?'s
Old May 25, 2003 | 09:10 PM
prowlingLT1's Avatar
Nitrious ?'s
what do you think will be the be the best nitrious shot for my motor in sig
Old May 25, 2003 | 09:30 PM
rage366's Avatar
*closes eyes and points at a number*
100 shot it is!
Old May 25, 2003 | 11:42 PM
Twice The Fun's Avatar
TNT (Texas Nitrous Technology) is a great kit, the jets are rated at rwhp, not flywheel as are most kit. a TNT 100 shot is about the same as, say a, Nitrous Works 125.
my TNT 100 shot dropped my ET from a 13.9 to a 12.6, 1.3 off ET aint bad is it.
Old May 26, 2003 | 09:26 AM
Brent94Z's Avatar
Super Moderator
I'll move this over to the Nitrous forum
Old May 26, 2003 | 09:47 AM
RacinLT1's Avatar
WHat crank rods? Stock?
What about the fuel system and ignition system?
With the forged pistons,150 would be no problem with the supporting mod's,and guys are even spraying upwards of a 300 shot.
I'd say 200-250 max to be on the safe side,but you still need to give more information.
Old May 26, 2003 | 10:14 AM
rskrause's Avatar
Moderator
I am not dissing TNT, I have never used on of their kits. But jets are jets. They are all the same, just a nozzles that come with different size holes. Bigger hole delivers more nitrous, simple as that. It doesn't matter what they call 'em, but what the diameter of the orifice is.
Now, different nitrous systems make different amounts of hp with the same amount of nitrous. There are a lot of reasons for this, some of them quite subtle. I suggest you read some of what David Vizard has written about nitrous to get a feel for the factors that play into getting the most out of nitorus. He says things more completely than I can, for sure. Just one major thing to mention here: street nitrous setups are almost always choked off by the exhaust. LT1's have a problem with getting the combustion products out in the first place due to everything from head flow limitations to the exhaust system design. Adding a 100hp nitrous shot is like adding >100ci and trying to exhaust the combustion products through the same pathway. So anything you can do to improve exhaust flow will increase your gain from N2O.
Rich Krause
Old May 26, 2003 | 11:34 AM
TMDZ28's Avatar
will a TES edelbrock headers and a cut out help the flow in using nitrous??
Old May 26, 2003 | 11:52 AM
funina91ss's Avatar
was your motor built for N20?You really need to know if the rings have been filed for the right size?If they were filed to stock spec. I wouldnt go over a 200 shot(rings Xpand when they get hot)but if they are gapped a little on the big side 250-300 with some timing retard.
Old May 27, 2003 | 01:27 AM
KTamez's Avatar
Rich Krause
THANK YOU Rich, Been trying to pound this one into some people's heads for awhile. I've often used the analogy that an N20 system and engine is just like a computer. $#!T in $#!T out. With very minor variations in nozzle atomization, line expansion, and efficencies, virtualy any system using the same size metering orifice (Jet) will produce about the same power.
In your 2nd paragraph, I'd note that although combination changes can be made besides the nitrous system (drastic items being Cam timing and exhaust flow as you mentioned) these still do not effect that any given amount of nitrous will make the same power no matter the sticker on the solenoids. a 52 jet may make 100 or it may make 115hp, but no matter the company the same orifice size will be relatively the same hp, given the same engine and operating conditions.
I hope that jibberish made sense, its starting to get late LOL.
That said, I wouldn't say there is any "best" setting to run. It boils down to your goals. If you have lofty goals, then you may or may not need to re-evaluate your goal if the parts aren't up to the task. How fast do you want to go?
Old May 27, 2003 | 04:43 AM
i understand completely what you fellas are saying about jet sizes and totally agree. I chose the TNT kit, bcuz the F1 (lower level) kit, comes with 75 - 125 jets just as do all other "lower level" kits....but my 125 jet is the same size as my friends 150 Nitrous Works jet. Therefore it seemed feasible to me that buying the F1 TNT kit was a good idea bcuz i would have that extra little edge than the next guy, but still on what is classified as a 100 shot......more or less, its just a reassurance, i guess....All I know is I am very happy with the way the kit is set up, i.e. spray bar plate, nozzles, and so forth. nice clean setup!
Old May 27, 2003 | 09:37 AM
LPEdave's Avatar
... and I have a bridge I'd like to sell you....
Dave
Old May 27, 2003 | 01:10 PM
rage366's Avatar
Dave
lmFao!
hehe, so much nitrous confusion...yet another reason to blow my wad on my NA motor.
hell, ~12k on mods and the *****ing thing still isnt ready.
Chrome383Z
Jul 23, 2009 07:17 AM
LUDA0840
N2O Tech
Dec 12, 2005 03:18 PM
Mystic97Z
N2O Tech
Mar 29, 2005 09:02 AM
dsheola
Jan 19, 2005 04:12 PM
94TEALz
N2O Tech
Mar 11, 2003 11:18 PM
