Quick setup ? for my new nitrous kit
Old Jun 12, 2003 | 04:05 PM
FirehawkNS's Avatar
I just got my NOS kit installed 2 days ago. I have everything for it except the RPM Activation Switch. I have the HPP3 programming on the car now, I was wondering while I am waiting on the Activation Switch if I could use the HPP3 to set the shift points earlier (like -2 MPH ) and be safe spraying through the shifts (A4). I just want to test this thing out and it might be a little bit before my MSD box gets here. My plans where to flip the switch at a certain RPM and then flip it back off at another.
What do you guys think?
Also, is there anything I need to make sure is off of the HPP3? I plan on leaving the 160 stat settings!!
nick
Old Jun 12, 2003 | 06:01 PM
thewinner's Avatar
the HPP advances the timing correct? i dont think you'll want that in the pcm program
Old Jun 12, 2003 | 06:22 PM
funina91ss's Avatar
If it were me I would wait. just takes on hit on the revlimiter to blow the intake off an LS1 . but you might be okay if you raise the rev limitier up too but keep that in mind when you get close to the revlimiter.
Old Jun 12, 2003 | 09:24 PM
FirehawkNS's Avatar
Well since its an A4 and I set the rev limiter to 6700 RPM's and I set the HPP3 to shift the car at 5600 RPMs I am not to worried about the rev limiter. I am just worried shifting while spraying. I can set the shift even sooner if I want. Also, I took the timing and power tunning that the HPP3 does off, so that isn't an issue.
And other thoughts!!!!
Old Jun 12, 2003 | 09:29 PM
funina91ss's Avatar
just pray that it dont hit the revlimiter. but really you should be ok. but mine did hit the revlimiter when I first put my kit on good thing I had the MSD 6AL. trans was going south.
camaroguy50613
May 27, 2016 09:00 AM
RUENUF
Mar 13, 2016 03:39 PM
Jan 23, 2015 01:13 PM
bandit383lt4
Dec 21, 2014 09:12 PM
