Nos on a stock LT1
Old Jun 11, 2003 | 04:30 AM
FrostZ28's Avatar
Nos on a stock LT1
Hey guys just a quick question. I was told that I could put a NOS kit on my car, its basically stock except for exhaust and a ram air kit. Is that true or should I have other stuff done first? I don't want to break anything but I would love to have nitrous. Thanks.
Old Jun 11, 2003 | 05:35 AM
RUFFIDLNZ's Avatar
Yes you can put nitrous on your stock engine. You just need to get the basic saftey parts and I would keep the hp in the 100 range. I would also get me an aftermarket ignition or at least a coil if you cant afford the whole ignition. You will also want to go to a heat range cooler plug. Other than that your stock motor will be fine.
Old Jun 11, 2003 | 10:36 AM
TMDZ28's Avatar
you need to get
- ngk tr6 sparkplugs or similar. (as stated above, cooler plugs)
- window switch (harlan or msd)
- WOT switch (usually comes with the kit anyway)
- actication switch (comes with the kit)
when you have some extra money, get:
- msd 6al (around $100-150 used)
- walbro inline fuel pump (around $150)
- bottle heater (around $200)
make sure your opti and sparkplug wires are in good conditions, you dont want a misfire while you are spaying, and never spray below 3000RPM. you should be set.
hope that helps
Old Jun 11, 2003 | 02:51 PM
FrostZ28's Avatar
Thanks guys. You mentioned making sure the wires and opti were in good shape. I know the wires are good I just got them replaced. unfourtunately the plugs were just done too, if I have to change them then it was a waste. Anyway what I was wondering is if there is a way to check the opti. I had it replaced aprox. 50k ago. I know that is kinda a long time but I haven't had any problems so I think its ok but I would rather be sure before I go any farther. thanks again.
oldschool
Feb 9, 2016 09:21 PM
D1SC383LT4
Jan 1, 2016 01:56 PM
Jason Short
Jan 19, 2015 06:34 PM
Brandon Wittmer
Dec 3, 2014 09:28 PM
