Quick ? for you guy's about type of fuel to use while sparying a 175 shot
From: Albuquerque,NM--5,600 feet above you sea-level cats
This is on my Solid Roller 396. It sits at 12.5.1 compression, and 175 is the biggest shot I'll be useing. Only time it will get sprayed is at the track. I was thinking of using C16 because of the compression. Just not sure 101 will handle it. What do you guy's think. I've also heard of 110 unleaded somewhere, but am not sure if that's true????
Neal
Neal
I have used Torqo's NOS 118. This fuel has a specific fuel gravity for nitrous and is also a slow burn fuel. This fuel sucks when not running on the bottle. But then again I spray just about double that shot and my combination is designed for nitrous with compression in the range of 14.1.
If I was you I would never run race gas out of a pump always get it from a drum plus with the fact of 12.5.1 compression and 175 shot depending on the cam you run as long as there is some overlap to bleed of some cylinder pressure I would tell ya to run unleaded 112 from Torqo. Just becareful of the fuel gravity and weather or not the fuel is oxginated, this will melt a motor quik on the bottle. Remember if running leaded race with the factory O2 sensor the lead will coat the O2 sensor and kill it ! Thus making the car very fat!
Good Luck!
Good Luck!
