purge kit install
Old Jun 5, 2003 | 11:33 PM
talos's Avatar
purge kit install
some thing that i could do in my driveway?
how much work is involved
Old Jun 6, 2003 | 11:46 AM
john97z28's Avatar
I'm doing mine in my driveway tomorrow. Not too much involed. Running wires is the PITA. I just need to pick up a t-compression fitting 1/8"-1/4" and a few feet of 1/4" brass lines and I'll be ready .
Old Jun 8, 2003 | 08:40 AM
funina91ss's Avatar
this is very easy to hook up depending on the kit you migh not need the T fitting. And for the purge line I used the copper tubing too. got it at advance auto it was there copper gauge kit.
Old Jun 9, 2003 | 01:52 PM
john97z28's Avatar
I had mine complete in less than 45 minutes on Sunday in the driveway.
Old Aug 29, 2003 | 03:37 PM
cjksflorida's Avatar
When you all installed your purge kit did yall put it on the inlet side or the outlet. Also where did you get your "T" at. My solenoid only has a inlet and an outlet so I'll have to "T" off for the purge.
Old Aug 29, 2003 | 03:44 PM
funina91ss's Avatar
what brand kit are you using??? if its NX it says N for nitrous and P for purge.. I am not sure on the others.
Old Aug 29, 2003 | 07:13 PM
No it's NOS, I guess the NX kit has three ports on it, but the NOS only has 2.
Old Aug 29, 2003 | 11:26 PM
NOS doesn't provide a purge port. You have to use an inline "gauge adapter". I am pretty sure it comes with the NOS purge kit. The -4AN adapter simply fits in between the end of the supply line and the -4AN fitting screwed into the solenoid. Then there's a 1/8" NPT threaded oulet on the side of the adapter for a nipple between the adapter and the solenoid.
LeftoverChinese
Jan 14, 2024 03:03 PM
Jan 23, 2015 01:13 PM
CARiD
Jan 14, 2015 04:00 AM
Dec 4, 2014 11:56 AM
