going up to a 175-200 shot
I have no way of backing off timing but I will be running 104 unleaded I also run autolite 103's gaped @40 if you guys have any more info on things I should do before spraying a 200 shot let me know I dont think the 175 will be a problem.and this will just be for one night our local track is having a heads up street car race. and I think I will need the 200 shot to be competive.(Pray for me
i going to try the same thing with the 200 shot but first im buying a bigger fuel pump just to be on the safe side. won't a msd multi-step retart box be helpful? good luck i'll watch for your results
Originally posted by 1QUIKTA
Good luck Sean and I heard about Adam's run
I would say if you are running the "stock" bottom end the main things you are gonna need is:
1) Adaquate fuel pump
2) MSD digital 6 or retard box to take out 2 degress of timing
3) 100 or better octane fuel
4) And some good tires to put that power to the ground...
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 11:56 PM
Sep 18, 2015 03:46 PM
NewsBot
Sep 15, 2015 11:53 AM
