Wet and Dry shots
Old Jun 1, 2003 | 11:31 PM
SantaCruz163's Avatar
Wet and Dry shots
I always hear wet shots and dry shots, but I am not real sure what the difference is between the two. Can someone tell me what the difference between the two is, and which would be better with forged induction.
Old Jun 2, 2003 | 02:00 AM
Revis_Racing's Avatar
A wet kit injects both nitrous and fuel into an engine usually through the same nozzle. wet kits are more complex and are almost impossible to hide. Wet kits are also known for their violent back-fires, which could destroy an engine or just bend throttle blades and burn mafs. Wet kits also "hit" harder, not produce more power with same jetting, but come in more violently, sometimes lighting up tire when you through the switch.
A dry kit injects only nitrous and then fools the computer to add more fuel via injectors. Dry kits are much safer, "hit" less violently, and are easy to hide.
But a dry kit sometimes doesn't like built motors, and you can't use a dry kit for really big nitrous shots like 250-350+.
Dry kits = 50-175hp, unless you use cheater solenoids.
Wet Kits = 100-500+hp, for the serious nitrous guys.
Old Jun 2, 2003 | 06:11 PM
Hawk's Avatar
wet is where it's at. Backfire, never had one, but i'd rather have that then have a injector lock up with a dry shot...............
Jeff1904
Jun 5, 2016 05:00 PM
68camaroboltz
Oct 5, 2015 11:56 PM
Sep 18, 2015 03:46 PM
NewsBot
Sep 15, 2015 11:53 AM
damnyankee36
Sep 9, 2015 07:06 PM
