NOS 5177 kit??
Old May 17, 2003 | 03:06 PM
torched's Avatar
NOS 5177 kit??
I found a deal on a used NOS 5177 kit for the LS1. Would this be an easy modification to get to fit on my LT1?? What would need to be modified?? and would this be a good SAFE kit to run only around on a 75-100 shot??
this is what he said it comes with:
1 used solenoid and one new one that has not been used, the bottle, bottle brackets, main line, Fuel Pressure Safety Switch, Blow Down tube, 2 lines that go from solenoid to lid, 2 bottle brackets, relay, WOT switch, assortment of the nessesary fittings.
Is this the complete 5177 kit?? and is $350 a good deal??
Old May 17, 2003 | 05:56 PM
I answered a similar question on LT1 Tech
http://web.camaross.com/forums/showt...hreadid=121388
The problem is whether you can get away with spraying an LT1 in front of (through) the MAF sensor. The LS1, according to NOS has a faster processor in the PCM and stays in closed loop at WOT (LS1 owners will dispute this). That's is how NOS explains the difference bewteen adding fuel using the MAF (LS1 5177 kit) and adding the fuel by boosting the fuel pressure (LT1 5176 kit).
There is also a thread currently on this board about people spraying through the MAF, and there are a couple people who have psoted that they have done it.
Old May 17, 2003 | 06:39 PM
torched's Avatar
haha, that's my friend who made that post. he also found a 5177 kit.
I wonder if that would be an easy modification to work on an LT1
lt1xondeck
Mar 18, 2016 07:22 PM
95z28man7
N2O Tech
Aug 16, 2015 10:58 AM
LeftoverChinese
Jul 23, 2015 03:57 PM
Jlo
Jul 22, 2015 05:00 PM
colts0455
Jul 20, 2015 09:52 AM
