PDA
View Full Version : Advanced Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18
  1. Disturbing.. GM hightech article LT1 spun bearings
  2. SBC, cam, stall, rear gears, nitrous oxide
  3. Any advantage to coating or painting the INSIDE of the intake?
  4. Lashing valves with feeler gauge?
  5. Rich and richer...
  6. figuring converter slip from dyno figures
  7. AC intake?
  8. ram air a myth?
  9. Cola Ultra-Lite U Crank??
  10. Taking out T56... ecu related ?
  11. Wiring diagram to install fast
  12. Question for people running 5.7" Eagle H-Beam Rods
  13. tire presure at the dyno
  14. spring pressure. How much difference is allowable?
  15. head surface question
  16. RR 23* heads vs standard 23* heads?
  17. houston, i think we have a problem...
  18. Any advanced way of telling if valve springs are too small?
  19. Knife edging a crank..not really "how," but "where?"
  20. Head stud nuts won't clear between "big" springs
  21. 383 to 396 stroker
  22. Front end question (engine)
  23. How much does coating add to size
  24. COMP XE hydraulic rollers vs. Crane Powermax Hydraulic Rollers????
  25. stacking head gaskets.
  26. low tention oil rings for street
  27. Engine Building Checklist SBC
  28. changing springs, but i cant get the locks off.
  29. spark lines look like a heart monitor! Pics
  30. Main cap orientation?
  31. Blown LT1, Block Fill?
  32. how to pre oil brand new engine???
  33. push rod lenght 7.05 to small??
  34. Cylinder pressure vs. Volumetric efficiency
  35. how good are ported iron eagle heads?
  36. Reduction Of Friction
  37. Suggest a Nitrous cam for 300 shot
  38. HEMI cumbustion chamber bad for performance?
  39. Anyone have any experience with Canfield Aluminum heads?
  40. Crank Selection
  41. hi-pressure z-28/lt-1 oil pump
  42. LT! third gen swap done, wont run, HELP
  43. Advanced Oiling System Troubleshooting&Questions.
  44. last hope
  45. Bore size?
  46. Degreeing a cam correctly..
  47. Why use dino oil after head/cam install and not synthetic?
  48. Anyone using DFI, FAST, MoTec ... HELP
  49. Wiring...97 3.8L gets built LS1
  50. How to cut 5" holes in alum.?
  51. Is it safe to run extra oil??
  52. Early model or Late model block?
  53. Ceramic Coating
  54. cam numbers
  55. All else being equal, how much HP per cfm?
  56. Suggestions on heads?
  57. stroke vs bore
  58. Can you open up the exhaust side of head to match 1470 gaskets?
  59. Racing Vacuum Pumps
  60. Corvette launch suspension
  61. CFM though a tube (MAF, throttlebody, etc.)
  62. Sollid roller build up finished...bad squeek!???
  63. 400 bore vs 350 bore: Valve shroulding?
  64. Can an engine live on 2 lbs oil pressure?
  65. floating pin install question
  66. biggest impacts on fuel consumption?
  67. porting heads
  68. Valve Lash
  69. Problems installing crank gear
  70. 2 Q's about Victor style intakes for EFI and rear mount dist.
  71. Best piston shape for flow
  72. Primary tube and collector diameter question...
  73. symptom of a timing jump?
  74. Dry sump vs. wet sump
  75. Ignition signal electrical question (waveform)
  76. LSA vs. horsepower
  77. Sorry didn't know i couldn't ask for advice
  78. build an LT1 for torque or horsepower
  79. Rasing the roof on an LT4 intake runner?
  80. Requesting Help from Advanced Members, Please.
  81. Hesitation Problems
  82. 383 Dyno Numbers See Inside
  83. tranny tech
  84. Please help me.
  85. Long Rod 383 w/ a twist
  86. valve spring compressor
  87. Borg Warner T-56. Holy or Unholy?
  88. is this enough spring seat preassure?
  89. Roller lifters in a Motown Block?
  90. Blowproof Can & Long Finger Iron Disk Clutch
  91. Rebuild to 383??? help guys plz
  92. What goes wrong on Cast Cranks
  93. Building a BB 454
  94. Blower camshafts vs Turbo Camshafts
  95. 540 inch rat for a....
  96. Slack in tv cable 95 z A4
  97. Rear mount distributor LT1
  98. Need help with cam sensor(2 coils fire)
  99. Is there a formula to figure out the horsepower limit of fuel injectors
  100. BIG problem filing rings!
  101. Exhaust crossover question
  102. 302 motor?
  103. LT1 Fuel Injection Problem, already tried LT1 Tech ... HELP ASAP
  104. complete new fuel line
  105. OK to skip checking valvespring installed height?
  106. Should you clean combustion chamber from leaky valve seals?
  107. Bad pcm unit cause tranny poblems?
  108. Breaking in sollid roller
  109. a4 shift points
  110. Why does my car sound like it's MISSING??
  111. missing and hesitation when getting hot
  112. How to figure in for auto tranny slip?
  113. Taper in intake shape
  114. Oil accumulator mounting position
  115. valve vacuum leak tester
  116. 85MM LS1 MAF On a LT1
  117. Head porting and FI, ???'s...
  118. Oil effecting power?
  119. Low lift cams vs. High lift flow heads?!
  120. how to find dynamic compression ratio?
  121. T56 Overhaul kits
  122. Dyno problems and A/F ratio question
  123. Torque specs for Eagle H-Beams?
  124. Drivetrain Strength
  125. Transgo separator plate- and question
  126. k members
  127. AUC, but where is it important?
  128. T-56 swap to Turbo 350 Transmission
  129. HELP oh wise ones... twin line lock and 2 step question...
  130. is there any way to do this???
  131. 3.8 liter rebuild
  132. Question for all running the LTCC
  133. Fuel Rail Pressure
  134. oil vent tubes in lifter vally
  135. Does side gapping plugs decrease fuel economy?
  136. Cometic head Gasket users in here
  137. fuel pump question!!!
  138. Advanced look at flywheel, clear up some myths
  139. Intake ccs vs displacement?
  140. Carbon fiber?
  141. Opti and Carb
  142. 1 gallon fuel cell enough?
  143. Hydraulic Lifer Preload Near Max Spring Lift
  144. fuel delivery vs camshaft timing
  145. Valve spring diameter
  146. I6 vs v6
  147. Vacuum To Mechanical Carb Conversion?
  148. $6000 and broken valve seat
  149. Rocker Arm Ratio vs. High Lift Cam
  150. Complete DIY A4 rebuild thread
  151. a4 rebuild
  152. Domed Pistons : How much power is lost?
  153. Spring Height and Stud Girdles
  154. Help with cam selection
  155. Is it cavitation or lack of oil?
  156. Vacumme Modulater on 4l60e?
  157. need help with roller rockers/misfires
  158. Can anyone identify this tunnel ram?
  159. cam base size ?
  160. Arao High Port Heads
  161. Short Deck Vs Tall Deck: What's the Diff?
  162. Carb conversion on lt1
  163. Chrome Moly Rear End of Mild Steel?
  164. torque specs
  165. Need Help With 95 A4 Tranny.
  166. Help
  167. Pumping losses at WOT: 92-94kPA MAP reading
  168. Home Made Octane Booster
  169. BBC 489 build up...need opinion...
  170. Lemons Headers vs. Stahl Headers?
  171. 383 versus 434, all things being equal...
  172. LT1 Super Ram Accel Intake - Any perf benefit?
  173. Need some suggestions about my problem!
  174. Piston Travel and Crank Rotaion vs. Valve Timing
  175. intake manifold options for AFR 215 RR, stock(ish) hood
  176. cam, question guy's
  177. Forged Pistons
  178. melling stock volume oil pump que
  179. Sheetmetal valve covers that clear alternator.
  180. vavle lift: lobe vs rocker arm?
  181. Pros/Cons of using an accusump?
  182. Fuel System
  183. Q about C R.
  184. how to make a lean/rich indicator ?
  185. Q about TQ stall.
  186. SB2.2 2nd Gen?
  187. Combustion 101
  188. Largest exhaust valve possible on LT1 and Vortec heads
  189. 540 BBC Update, Dyno #'s, ET's
  190. Problem with connecting rods. Need help!!!!
  191. stock LS1 MAF on an LT1 motor
  192. A few interesting topics-
  193. Engine girdle?
  194. All this talk about 4 valve heads...what happened to the GM PRODUCTION 3 VALVE HEAD?
  195. Water injection...
  196. Racetronix twin intank setup: tuning question
  197. Swirl RPM vs CFM
  198. Strange Engineering 12 Bolts...
  199. parts needed for an l67 rebuild?
  200. 750HP LT1 Daily Driver
  201. 380+ hp w/ 8.3:1 compression, what octane fuel?
  202. Block filler?
  203. Intake vs. Exhaust valve lift and cam selection
  204. intake runner finish and epoxy ?'s
  205. Q: induction style dual turbo setup?
  206. Dynamic compression
  207. Please explain what happened to my engine
  208. A couple of questions about heads
  209. tranny probs
  210. Compression Ratio With O-Ring?
  211. Light weight sub-frame connectors
  212. need opinion on best lt1 connecting rod
  213. Lets discuss harmonics!
  214. ZZ4/ZZ3 cam W/ 95 Opti Possible?
  215. I want to use Granatelli LS1 MAF, need help!!!
  216. Overall Issues of Head Porting
  217. Need help tracking down a sound, please!!!!!
  218. 4 bolt splayed & oil dipstick
  219. Carburator Detailing - Anodizing/Cleaning
  220. Does my motor need rebalancing?
  221. Intake Manifold flow vs Head flow
  222. Stroker possibilities with a 400 block?
  223. would 236 / 244, .510 / .540 114 LSA pass emissions
  224. Toluene - How long can it sit in a tank before damage occurs?
  225. Tunnel Ram Shootout
  226. Th 350 swap
  227. Point of diminishing returns with head flow on an NA application? Such a thing?
  228. Advanced look at Strut Tower Braces
  229. Head Porting Victor Jr's
  230. Tunnel Ram Carb Requirements
  231. 700r4 troubles
  232. Is there a formula for determining optimum plenum volume?
  233. F.A.S.T. tuning 383 stroker
  234. Brake calipers in front of or behind the axle effects?
  235. I beam rods or H beam rods? which to get?
  236. CAI design and assoc power losses and gains?
  237. ?'s regarding block fill and knock sensor operation
  238. Advanced Look at Spark Plugs (Heat Ranges).
  239. Car overheating?!?!
  240. Solid roller cam maintenance
  241. Weiland intake torque specs?
  242. Sollid roller cam help
  243. T-56 tailshaft bushing
  244. Braking Dynamics question- COMPLETLY Theoretical
  245. Link Management Systems
  246. Drilling Struts
  247. sb2.2 conversion
  248. formula for fuel pressure ?
  249. TH350 kickdown cable in a 4th gen
  250. 4-bolt main caps
