PDA
View Full Version : Advanced Tech
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18
  1. Lube on threads.. does it increase torque accuracy?
  2. Grinding BBC bores to unshroud valves......
  3. OHC SBC's
  4. Code 43 trouble
  5. Is there a good way to replace my optispark with an alternative distributer?
  6. testing injectors
  7. Electrical Wiring
  8. Thoughts on EGR
  9. Rhoades Lifters
  10. What type of drill bit do you use on a cam gear?
  11. cam change when changing from alcohol to gasoline?
  12. Leaded gas
  13. No compression
  14. pistons for 5.7" or 6" rod better for 383 DD build?
  15. Engine Builder's Notebook
  16. CAM and VALVETRAIN gods, in here!
  17. fabricating longer runner LT1 intake manifold
  18. Need opinoins on leakdown test results
  19. Dynamic Compression Ratio?
  20. Comp XFI versus Extreme lobes
  21. stroker head gaskets
  22. 396 piston speed vs 383 piston speed vs head flow ability
  23. Fbody LT1 to carb conversion?
  24. Got a great deal, now i need some advice
  25. Installing Cam with both Heads offf?
  26. Keeping Fuel Cool
  27. Cam Design
  28. Teflon Coating Intake Runners
  29. What type spark plug tip with boost/N2O application???
  30. stroker main stud and head bolts
  31. looks like my machinist messed up
  32. Which head/intake combo?
  33. LT1 TFS head issue...bad casting?
  34. My Big Block into a 4th Gen install journal...
  35. Looks like I'm getting some crank walk.
  36. Aww shoot! Piston looks like a piece of Swizz Cheese
  37. A "pro's" view on engine coatings
  38. 383 not running right after rebuild
  39. Hyper-square motors?
  40. Hypereutectic aluminum pistons and nitrous.....safe?
  41. A "pro's" view on rod length.
  42. 1st gen sbc heads on a lt1
  43. Checking Valve sPrings height
  44. Internal vs. external balancing
  45. Oil problem?
  46. Reading plugs to determine rich or lean
  47. advanced missfire
  48. The SB2 LT1 lives
  49. Results of carb to EFI conversion
  50. Crank adapters?
  51. new cam, advance, retard or straight up?
  52. Advanced Misfire Problem
  53. Cometic Head Gaskets
  54. Degreeing Cam @ IVC
  55. Hellfire Rings
  56. Degree Wheel
  57. Miniram an upgrade?
  58. Dual Sync Distributor
  59. An interesting statement
  60. Need engine rebuilding advice...
  61. Motor swap time, need advice from the pros
  62. Block Prep 101
  63. Initially Setting Valve Lash
  64. Cleaning aluminum heads
  65. Intake Port Volume Confusion
  66. What the inside of an LT1 intake manifold looks like
  67. advice on vic jr to lt1 swap
  68. Hot Tank Proof Paint?
  69. Retorquing heads - need advice
  70. can someone answer these questions for me
  71. Need Immediate Help with Mighty Demon 825!!!!
  72. Started New 383 Le2..idleing Issue
  73. URGENT HELP!!! Flat Top or -16cc?
  74. Oil volume at sending unit vs above oil filter question...
  75. Leaded fuel in EFI LT1; Denso O2 sensors
  76. Oil Control Questions
  77. compression question?
  78. BBC/SBC carbd 4th gen cars
  79. Headers are glowing ... Very strange problem
  80. DCR Help
  81. Paging Bobby Simpson
  82. Headers hit steering gear box??? HELP
  83. Roller springs vs Flat tappet springs
  84. 4 Bolt Main Splay Question
  85. ICS Titan Head gaskets by SCE???
  86. XFI 218 Cam Or Custom Cam
  87. lt1 heads
  88. dome top pistons hitting
  89. Custom EFI setup
  90. judging hp based on injector duty cycle?
  91. Detonation Obvious On Rod Bearings...???
  92. Larger throttle bodies...
  93. What thickness spring shim? No access to a checker.
  94. Interpreting plastigauge readings... Help
  95. What's More Important for HP
  96. Micrometer question
  97. Anyone know about Oldsmobile Auroras?
  98. 350 into fourth gen camaro pics and info
  99. cyl walls to thin for resleeve, what to do?
  100. (stalled) automatics VS manuals... dyno comparisons...
  101. What would you do?
  102. Boost + N2O + Meth injection??
  103. Cylinder head problems
  104. Good Fuel Pressure Setting for SBC???
  105. 383 Engine Simulation
  106. 1.5 or 1.6 Rockers on a Solid Roller Cam ???
  107. Engine design
  108. Is this normal for oil psi in a 383?
  109. Rear Windshield Wiper
  110. need help undersstanding fundamentals of our ignition system, i changed everything!
  111. Doing a paper on valve springs, need help!
  112. Rod Lenght.....
  113. Electric or Mechanical Fuel Pump???
  114. Yes, there is such a thing as a cam that is too big!
  115. Independent Rear
  116. DCR & Cam Geometry LT1
  117. L6 Q.
  118. 383 stroker diagnostics LTCC
  119. Tuning for my stroker?
  120. 4th gen bbc headers
  121. Using the stock thirdgen radiator with LT1..
  122. Rust on Rockers?
  123. Intake CC...volocity vs. volume?
  124. Anybody run a half-filled block?
  125. Header Adapter Plate
  126. Fuel System for standard SBC coversion in 4th Gen
  127. Opinions on King "alecular" bearings?
  128. Quench with this piston
  129. Air/Fuel Ratio A/F
  130. Carbon Nanotube technology
  131. did i mess something up? (lifter)
  132. Cam repair???
  133. I thought it was futile to sleeve an LT1
  134. Any thoughts/impressions on this?
  135. Sheet Metal Intake under 7000 RPM's
  136. 1.8" spring recommendation for cam
  137. G5X4 Cam specs.......
  138. VersaFueler
  139. Resleeve No4 cylinder?
  140. Where do we stop with bearing sizes?
  141. Crack in bore
  142. Rod length (?)
  143. chamber cc and milling has an effect on flow numbers and port velocity?
  144. Suggestions for setup
  145. rhoads lifters
  146. ABS Sensor Signal to EBCM
  147. best single plane intake design
  148. Piston selection
  149. Breaking engine in proceedure
  150. Who's right?
  151. High(er) RPM cars, who's is/isn't running the stock style lifter spider?
  152. rocker arm q
  153. Engine Lacks power
  154. external oil pump question
  155. help! oil pan on 383
  156. AFR or Brodix
  157. Too much timing chain slack?
  158. 225 psi is my timing chain off?
  159. Acceptable tolerance rod big ends?
  160. I've searched and read about it, but still have a ? 6.125" rod
  161. Scr:dcr - Ivcº Abdc
  162. Gen 1 SBC (mid late 70's) and LT1 top end?
  163. Technical discussion on what would cause a piston to explode at idle
  164. Alright well it's that time again
  165. Questions about AFR's
  166. Block Strength, Dart vs. GM
  167. honing for piston fit
  168. Which is better?
  169. sodium-filled exhaust valves
  170. Timing chain q
  171. '06 Engine Masters
  172. Coating the block internally.
  173. True or False? #2
  174. Intake Velocity Versus Compression Ratio
  175. 60lbs forged crank or 53lbs cast crank?
  176. 2-piece crank/flywheel question
  177. Block swap
  178. 91 camaro vacuum diagram
  179. LT1 cam in 91 350 TBI
  180. How do ported heads change the characteristics of a motor?
  181. manley pro-flow or LT4 valves for every day driving
  182. Making my own headers. Questions
  183. Building a custom intake manifold.
  184. anybody have any flow numbers of bare bbc intakes
  185. MAIN CAP WALKING ISSUES!!!! High rpms
  186. DCR with E85?
  187. Shelby VS Smokey
  188. Switching engine combo's
  189. Just wondering about camshaft duration
  190. can a stock FPR handle a stroked motor
  191. Please Help With BBC Questions!!!
  192. Electrical Design for Racing
  193. Piston Question
  194. Rod Oil Clearance Not adding up?!
  195. EXhaust Building Questions
  196. Motor plate question
  197. Need Help With LT1 into Pre-Runner
  198. DTI P&P Kit. Are they worth it???
  199. Got bored this weekend....
  200. taking out a/c
  201. Eagle Cast Crank Ground 40 over
  202. Engine block strenght: L98 vs. LT1
  203. RACE TECH Magazine: F1 Engine HP, Torque, RPM, etc.
  204. Camshaft
  205. Mahle Bearings
  206. How to tell the stroke of your crank shaft?
  207. Shaft Mount Setup
  208. Found a Gen V 454 - good deal?
  209. Single plane good for turbo???
  210. Maximum DCR before coating is required
  211. stock lt1 heads.
  212. Custom Cam Grinding...Where?
  213. Piston Speed
  214. How do you determine what # injectors you need?
  215. Discolored Rocker Arms...
  216. Oil blowby detonation help?
  217. Will detination cause the top areas of bearings to shave away?
  218. Alky Injection on a NA Motor?
  219. Roll Cage and Street Safety?
  220. Anyone running LT1 on alchahol?
  221. single plane???
  222. 4Th Gen Aerodynamics
  223. 15 degree pontiac heads and intake??
  224. Fastener engineering question
  225. How do they make piston rings have that "spring" to them?
  226. alright need some opions
  227. Does anyone make 4.040 X 3.875 X 6 in rod pistons?
  228. Where can i get ahold of the machine draftings....
  229. Dyno Q:
  230. Any machinist?
  231. Problem with Stud Gridle Rocker Arm Nuts
  232. Crank Trigger -vs- Dual Sync Distributor
  233. couple questions on my 398 lt1
  234. What type of alum is the bell housing made out of.....
  235. How do Dynos Actually Work????
  236. opti spark replaced?
  237. Taste Test...
  238. TDC pointer
  239. stroker questions please help
  240. custom clutch system design
  241. Blowby / Piston skirt scuffing
  242. bore vs stroke 2
  243. Accel Gen 6 wiring instructions????
  244. heads
  245. Ok gearheads, check this out!
  246. Valvetrain Weights
  247. Bearing discussions
  248. big cube small blocks?
  249. Ring gaping ?
  250. Something I've never understood.
