how to find dynamic compression ratio?
I 've seen some people talking about DC, I did a search but still dont know how to find out what mine is ,and if it is ok for the street? can someone show me or tell me , thanks
There is a computer program which helps out.... or you can do it in you're head. There is a book called Auto Math which has it in there. If you want, let me know and I'll see if I can email you the program... it is small. about 1 meg...
Thank you Rich!
This is the equation I put together in Excel:
DC = (((Stroke - (Stroke / 2 - Stroke / 2 * COS(IVC * 3.14159 / 180))) * 3.14159 / 4 * Bore^2 * 2.54^3) + CompVol) / CompVol
CompVol = Chamber volume + piston dish volume + gasket thickness volume + deck height volume (all in cc's)
IVC = Intake valve close timing at .006" = (Advertised duration / 2) + LSA - Advance - 180
Remember, solve within parenthesis first, exponents second, multiplication/division third, then addition/subtraction fourth. The equation won't work otherwise.
Using these numbers on my former 383 with 11.25/1 compression and a Crane 296/304 hydraulic roller (234/242 on a 112, +6 adv.), I get a DC of 7.5/1. From experience, this motor ran on 93 octane, but wouldn't tolerate more than 36 - 37 degrees total timing. It made very strong midrange power and ran 11.09 at 122.7 mph.
Mike
Mike
Mr. EngineerMike let me upload for all the excel spreedsheet to simply things for everyone.
http://www.geocities.com/kmook123/DCR.xls
Thanks Mike
Thanks Mike
