Question for people running 5.7" Eagle H-Beam Rods
You'll likely have to modify the pan rails to clear the rod bolts.
Regardless, I view this as a bad idea, due to the lack of sump depth along the front of the pan - it's just asking for windage problems. A deeper aftermarket pan is a very wise investment, based upon my experiences.
Originally posted by Andrew Coats
I just built a 383 with H-beam rods and I had to go with a canton pan. The rod bolts we're hitting the stock pan even after we clearanced it.
Originally posted by DarthIROC
THe Eagle H- Beam 3D rods are supposed to be stroker clearanced when yo buy them. DId you get the 3D rods?
Just finished a 385 and went with the stock pan. I have a Callies Dragonslayer Crank & Eagle 4340 H-Beam rods with ARP bolts. I had to massage the pan with a BFH for #1 & #2 rods hitting the bottom and Pound out the side a little where #7 was hitting. No problems after that and I'm using a windage tray with Melling HV pump.
oldschool
Feb 9, 2016 09:21 PM
Hurin
Dec 13, 2014 07:38 PM
