vavle lift: lobe vs rocker arm?
Every time I see someone talking about getting more valve lift out of the cam I see all the engine builders say to get the desired valve lift grinded into the cam instead of using more rocker ratio. Why? I dont understand the difference. Is there an advantage to having in ground into the cam as to using the rocker arm make up the lift?
Jeremy
Jeremy
Read this thread:
http://web.camaross.com/forums/showt...threadid=37457
It gives alot of info about this.
