cam base size ?
Old Jul 11, 2003 | 10:58 PM
bowtiepwr's Avatar
cam base size ?
>I believe I asked this before , but can't find it ???
Any who - what makes you have to go to a smaller cam base circle ?
Would the connecting rods dictate the size (cam base circle) that is used ?
I went with the Oliver Billet I beam 5.850" rods as opposed to the Callies 5.850" H beam rods .
Old Jul 11, 2003 | 11:41 PM
rskrause's Avatar
Moderator
Re: cam base size ?
To be sure there is no interference problem, you need to verify it by test fitting, or know someone with the same combo and no problem. That said, if it's a 3.75" stroke (383) you shouldn't have a problem as there are others running Olivers in a 383. Can't say I specifically recall seeing a 396 with them. The rod length shouldn't matter, since it's the big end that's the potential problem.
Rich Krause
Old Jul 12, 2003 | 07:32 AM
bowtiepwr's Avatar
Re: Re: cam base size ?
Rich Krause
>I knew that yea right .
I was trying to figure this out while in the shower (best time to think) I am getting so psyched , and can't wait to drive my garage floor down holder .
Thanks Rich
Old Jul 12, 2003 | 03:52 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: Re: Re: cam base size ?
Thanks Rich
just as a side note, it throws off some aspects of your valvetrain geometry- namely pushrod length. You will need longer rods to compensate for the smaller base circle.
Old Jul 12, 2003 | 04:13 PM
bowtiepwr's Avatar
Re: Re: Re: Re: cam base size ?
>Good point
I hope I get to stay with stock size cam .
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
pimpss96
Feb 12, 2015 01:28 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
ChrisFrez
Nov 23, 2014 10:33 AM
