Can you open up the exhaust side of head to match 1470 gaskets?
Old Aug 17, 2003 | 08:59 PM
Timberwolf's Avatar
I'm having my heads ported, and he wants to know which exhaust gasket I am going to use. I have used the 1406 before, but I am thinking the 1470 or 1482 will be better, and he can open the port more to match... any problems with that?
Also, does anyone know the port dimensions of the 1470? I know the 1482 is 1.74 x 1.60 (according to the SDPC catalog)
I've been searching the hell outta the web, but no luck so far.
Old Dec 6, 2003 | 05:04 PM
Larnach's Avatar
Little late, but my heads were matched to those on the exhaus side, with the bottom floor of the port opened up and smoothed out.
Old Dec 6, 2003 | 05:58 PM
rskrause's Avatar
Moderator
It only makes sense to match to a gasket if the other side of the gasket matches up to the downstream part. Not phrased very well, but hopefully you get what I mean. Also, there is no guarantee that there is enough "meat" in the exhaust port to allow you to match the gasket.
Rich Krause
Old Dec 6, 2003 | 06:01 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
you do NOT WANT THE HEADS TO MATCH THE GASKET! you will RUIN the heads performance, and probably strike water to boot!
Old Dec 6, 2003 | 06:03 PM
rskrause's Avatar
Moderator
Said better than I did. I know I didn't quite get the point across.
Rich Krause
Old Dec 7, 2003 | 05:10 PM
arnie's Avatar
Harley didn't understand this, and some here, I'm confident, do not understand this, but bigger into smaller is not good. In lieu of being preoccupied with the size of the port (at the flange), I'd be more concerned with the 'angle of attack', shape, and making it as small as possible, not as big as possible. Water? At that size, I wouldn't bet against it.
Old Dec 7, 2003 | 05:13 PM
Timberwolf's Avatar
wow, you guys dragged up an old post
Chris Anderson
Jan 27, 2015 08:30 AM
Jazsun
Dec 29, 2014 12:14 PM
thenewkid
Nov 27, 2014 09:41 AM
