Valve spring diameter
Old Jul 16, 2003 | 12:28 AM
mastrdrver's Avatar
Is there an advantage to running a larger diameter vavle spring? Say a 1.55 vs 1.46? Also how are the Comp R lifters better then the regular magnum lifters?
Jeremy
Old Jul 16, 2003 | 09:19 AM
cASe SenSiTive's Avatar
Exposed Member
A larger diameter spring will be able to have more total wire at a given height, increasing the spring's abilities. There's no specific "advantage" to them other than when running a cam large enough to need more spring presure. You shouldn't run much more spring than you need.
The "R" lifters supposedly are able to run better at high RPMs because they have an anti pump-up design.
FWIW I had a Comp R lifter come apart on me and f*** up my engine.
Old Jul 16, 2003 | 07:04 PM
KCFormula's Avatar
Just put long tubes and a cam in your car and lets run 'em!
Old Jul 17, 2003 | 04:42 AM
Eric Bryant's Avatar
Also, for a given seat pressure, open pressure, and lift, a bigger-diameter spring should be more durable.
DirtyDaveW
Mar 15, 2015 07:01 PM
carl.froehlich
Mar 13, 2015 12:38 AM
Red_94Formula
Jan 22, 2015 12:17 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Jul 4, 2005 05:00 PM
