ZZ4/ZZ3 cam W/ 95 Opti Possible?
Can anyone answer this question for me?
Can you swap the dowel pin out of a ZZ4 cam to work in a 95 optispark setup? If so how do you swap the pin exactly?
heres some info on how an lt1 cam differs from a standard roller. http://www.compcams.com/catalog/042.html
basicly i think you have to have the pilot hole cut deeper and the end of the cam turned down a little.
i looked into using this cam awhile back from what i can tell it'll make stupid tq and should actually be slightly better than the 210/224 from crane. good luck whatever you decide.
oldschool
Feb 9, 2016 09:21 PM
