Slack in tv cable 95 z A4
I just recently bought a 95 Z that had nitrous throttle plate taken off and I noticed that the tv cable is slack about 1/4th inch. Is this correct I know on my ford aod there is slight presure even when the throttle body is fully closed. Seems to shift fine but I think it should be tighter any ideas? thanks
I thought since the 4L60E (94-97) is electronically controlled, only the 4L60 in the 93's has a TV cable. Are you talking about the second cable on the side of the throttle body quadrent? That is the cruise control cable on your 95.
Might want to clarify exactly which cable you mean.
well Mr. Moron here, I do have cruise its on the side stalk like most Gm's have I had a brain fart (happens to us over 40) My stang has it on the wheel. Guess I've been driving fords to long
Thanks for the replies I guess even when you have gone and built 8 sec na cars you still can be stumped by something so simple before checking the obvious
Andel
Andel
