OK to skip checking valvespring installed height?
Old Aug 1, 2003 | 02:57 PM
Mullet Z28's Avatar
I know it's not the PC thing to do, but I've gotten away with it before for tens of thousands of miles.
At any rate, I'll be running Isky #9965 springs:
- 245lbs seat @1.950"
- 585lbs open @1.270"
- 1.170" bind height
- .680" lift
My main concern is not having adequate pressure if the heights are off.
Old Aug 1, 2003 | 04:03 PM
96speed's Avatar
Arrow Re: OK to skip checking valvespring installed height?
Duh! That's the whole point .
Its not just PC, its the only way to do it.
Ryan
Old Aug 1, 2003 | 06:39 PM
SStrokerAce's Avatar
You do have .100" of clearance from max lift to bind which is plenty, but I would definately make sure it's right. A little time is worth alot of money if something goes wrong.
Bret
Old Aug 3, 2003 | 02:13 PM
Damon's Avatar
No stock SBC head that I am aware of has a stock installed height that tall. Earlier SBC heads are around 1.75" in stock form, many aftermarket entry-level performance heads open that up to around 1.800-1.850. Haven't run into one that's as tall as 1.950 in stock confuguration.
You can get a reasonably close installed height from a $2 Pep Boys vernier caliper for cryin' out loud! With springs that stout (and probably a real nasty cam bumping things open) you'd be nuts to skip this simple but critical step.
HectorM52
Jul 30, 2017 11:46 AM
HectorM52
Jun 23, 2016 08:42 PM
Sergio
Jan 27, 2016 04:27 PM
cmdeshon
Dec 27, 2014 10:06 AM
danielbmx
Aug 27, 2002 11:11 PM
