Oil accumulator mounting position
Old Jul 29, 2003 | 11:25 AM
Dave Feerst's Avatar
I hope this is advanced enough for advanced tech....
I have an Air blatter moroso oil accumulator I am installing along with an oil cooler to eliminate my problems with hot oil and pressure dropoffs. The best place Ive found to put it is right beneth the ABS computer. But then it would be upside down(air bladder on the bottom) is that ok? Also it came with no instructions whatsoever and I've nver used one of these. Im assuming you fill it with about 5 PSI air pressure then fill it with oil before starting it??
Old Jul 29, 2003 | 05:15 PM
96speed's Avatar
If you relocated the battery and bought a new Summit catch can to replace the stock one/batttery tray you will have lots of room up on the passenger side front.
Ryan
Old Jul 29, 2003 | 05:34 PM
I thought about that. But I have subs in the back. Moving the battery is a last resort. Anyone know if the blatter can be installed with the oil outlet on top?
Old Jul 29, 2003 | 06:03 PM
Jeff Belloma
Guest
Posts: n/a
which model are you using? the -900, -901 or -930?
JB
Old Jul 29, 2003 | 06:44 PM
930
Old Jul 29, 2003 | 07:02 PM
Jeff Belloma
Guest
Posts: n/a
the -930 is gravity feed. you must mount it vertically. the oil feed will pressurize the canister when at full capacity. no need for outside pressurization. keep in mind that you will be pulling a quart and a half of oil from the crankcase so compensate.
JB
Old Jul 29, 2003 | 07:11 PM
thanks, is there some way to fill the cooler and lines and get rid of air bubbles before I start the engine?
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 07:11 PM
silvermansteve
Mar 4, 2015 05:02 PM
Jul 4, 2005 05:00 PM
