PDA
View Full Version : Advanced Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18
  1. Fuel return line ???
  2. HELP!!! Dynoe'd today, please read;
  3. A couple questions about milled heads and valve clearance w/ 2.055/1.60 valves??
  4. How does humidity affect power???
  5. Analyze my dyno numbers please ....loooooooooong
  6. factory 4 bolt LT1 block, can handle over 800 rwhp?
  7. big problems
  8. Head stud tech. What's correct? What's Not? Straighten me out please...
  9. How high of compression can you go on an LT1?
  10. What makes LT-1 reversed cooled?
  11. diy head porting question
  12. Modify Lt1 manifold to use distributor?
  13. piston to valve clearance
  14. gouged drive shafts
  15. More Cam Questions...
  16. Lifter question
  17. (long) dyno numbers/questions
  18. how to convert a standard Sbc intake manifold to fit lt1?
  19. Roller lifter retro fit, what cam?
  20. why/how does a stroker "tame" a big cam shaft?
  21. Hydraulic throwout on an LT1 T56?
  22. LS1/LS6 ported heads Vs AFR LT1/LT4 ported heads
  23. 3800 miles, cam bearings TRASHED
  24. who was making the machined opti-spark cover for multi coil cars?
  25. Building a 377
  26. Runnin on methanol
  27. Isky or Comp cam?
  28. Converting LT1 to 15º head
  29. 4L60E troubles
  30. Insanest cam on VORTEC heads
  31. High Perf 700R4 parts recommendations.....
  32. My Car has gone PSYCHO!
  33. 86 TPI top in on 350 in S10
  34. Octane--Pre-ignition
  35. Do not post "for sale" on this forum
  36. 396 questions
  37. seperately cooled heads
  38. xe 230/236 and crane 230/238
  39. Firing Order...Flat Fire
  40. Need help with engine math
  41. Oil pressure constant under all conditions- blearances, guages & pickup???
  42. Going back to 5.7" Rods from 6"
  43. Stroker Engine Longevity as primarily a daily driver
  44. 4L60E to M6......Wiring problem please help
  45. head/cam/headers combo or 383??
  46. Need information on stock harmonic damper balancing
  47. Engine Experts Please Help
  48. head porting question
  49. Position of Exhaust crossover
  50. Cross fire hardcore
  51. What is the formula for figuring injector size requirement for an application?
  52. block rust...
  53. Camshaft gurus.....need some help pleaze
  54. HELP GAS IN OIL never seen this b4 on a lt1
  55. 18* heads
  56. Allright, Final camshaft questions i promise = )!!
  57. Questions on Combustions Chamber Coatings??
  58. Gear ratio formula
  59. 383 D-1 w/ LS1 coil packs and no more opti
  60. 8.1L to LS1 Swap
  61. Anyone here have any input on this?
  62. Brodix Track 1 heads
  63. backpressure and torque
  64. Piston crown thermo barrier
  65. Raising Intake Roof
  66. Lugging engine in 5th and 6th gears
  67. LT1 Fuel Injection on a different engine. Doable?
  68. BBC in 4th gen Camaro
  69. headers to small or engine to big.
  70. GM 350 Block(10105123)
  71. stock valve size and head diameter please?
  72. Can you "overcam" your motor? Am I?
  73. Camshaft LCA statements within. ARE THEY CORRECT?
  74. max lift recommended ???
  75. Low end torque 383 w/ big port heads
  76. Best Flowing Stock Heads
  77. Guys with fast 6 spds, what do I need to keep from breaking them
  78. ceramic coating question
  79. How much money to "coat" exhaust ports in a cylinder head????
  80. What's normal MAP (psi) at idle?
  81. Limits of the stock fuel lines and rails
  82. Anyone read SUPERCHARGED! by Corky Bell?? Opinions please.
  83. Opti substitute for bbc to keep LT1 pcm
  84. What are your thoughts on thin stem valves
  85. What rings?
  86. Paging Injuneer or any other experts (long)
  87. What Type Effects Would Too Long Of A Push Rod Have On Engine Performance?
  88. compression vs head porting vs forced induction
  89. Conversion for Brodix heads?
  90. 2 piece rear seal adaptor for 86 and newer
  91. torque spike in automatics
  92. Stock LT1 internally balanced or externally
  93. Some fuel system calcs
  94. machine work
  95. Building 383-Use 5.7" or 6" rods?
  96. Pipe CFM, Muffler/Exit Location and Resonance...
  97. Best Crankshaft for LT1 Engine?????
  98. Last minute stroker start up questions... Almost there!
  99. Please Help!
  100. Mild 350 build questions
  101. arao 32 valve heads- what are you guys talking about?
  102. Finding Cubic Inches
  103. How much can I stroke this block for?
  104. Rebuilding transmission, got a quick Q
  105. How does air velocity relate to torque?
  106. Arao Engineering 32 valve heads
  107. Ford mustang 8.8'' rear for a 4th gen rear swap?
  108. Electric AC
  109. Motor didn't perform as expected what could be wrong?
  110. I just broke my second input sprag in 2 weeks. What the heck is going on?
  111. Titmium valves and the gains with it?
  112. what top end for a turbo lt1
  113. Let's talk about engine bearings.
  114. Head porting
  115. 1.65rr or 1.7rr's......Can it be done?
  116. Calculating actual load on the torque arm?
  117. custom grind cam request ???
  118. My 383 wont spin tires?
  119. Cam Question
  120. building engine this winter, questions about balencing
  121. 406s make more power than 400s I don't get it?
  122. Rod choice for hi-po/low rev setup?
  123. changing transmisions (a4 to 6m)
  124. Notching piston skirts for crank clearance?
  125. MSD DIS and coil packs how much?
  126. Pulleys/Brackets/Accessories
  127. 454... Will it fit?
  128. cam formula ???
  129. tranny mounting questions ...
  130. What gear to go with?: 4.10,3.90, or 3.73's
  131. Forged internals for a T56. . .
  132. 9" or 12 bolt (Noise)
  133. Injector Offsets needed???
  134. Aeromotive pump using stock lines
  135. Dyno and the consequences on an engine or car?
  136. Are expensive oil pumps REALLY worth the money....experience witin please
  137. If using new heads and new valves does it require lapping?
  138. Gen I 383
  139. Blower Pistons, rings, other misc. rebuild questions and concerns....
  140. I can't get the input gear out of the trans.
  141. WATER/ALKY injection on high comp. NA motors?
  142. Problem: i think my deck is past zero and piston is above it
  143. x 236/242 cam
  144. 50 over 383 is this ok?
  145. Discussion on headers and = length primarys
  146. glowing header question
  147. anyone running 6.125" rods on an LT1 383?
  148. Building 355- what's best bore/stroke?
  149. solid roller lifters?
  150. 383 Head selection with what piston ?
  151. How restrictive is the intake?
  152. Thinnest Quality Head Gasket Available?
  153. NEED HELP PLEASE!!! W/cross fire to fuel injection
  154. Swappin' Blocks
  155. Camshaft gurus in here please!!
  156. HP loss @ the rw
  157. would this work?
  158. piston oilers
  159. Dropping piston "in the hole" to lower compression?
  160. header flange question?
  161. Opinions on strokerkits.com..
  162. Pros/Cons of Overly large Throttle Body
  163. Help Wiring Inline Fuel Pump
  164. Water Jacket Or Head Gasket
  165. Anyone know about the TKO II or F-body cars with 2.73s???
  166. high vol pump.. another twist
  167. help with 383 set up
  168. bore distortion, measurements, and pistons
  169. Changing 6th gear ratio in T56?
  170. std. 1.7 roller rockers?
  171. Ideas on Rod lengths and Rod Materials
  172. Theory for bad opti.
  173. Moving the altnator
  174. Belt Drive on a LT1
  175. Removing guide boss in LT1 head??
  176. Is this right?
  177. Winston Cup Cars
  178. Whats the proceedure for adjusting rocker arms for a solid roller??
  179. Solid roller/lash question
  180. exploded diagram of th350
  181. LT1 Engine Balancing
  182. Using LT1-designed cam in L98?
  183. port velocity
  184. Stock computer with a Gen I engine?
  185. Theory: pushrodless LT1 engine?
  186. CVT "6-Speed" Tranny...
  187. Running a F-body on Alcohol
  188. A3 Swappers, what shifter cable lenth?
  189. Compression Ratio
  190. Pro's/Con's: 1-piece versus 2-piece seal cranks
  191. Alcohol Injection???
  192. timing at 7500 ft elevation
  193. Unusual mod, ver unusual
  194. 350 block
  195. Cylinder head flow efficiency
  196. 383 build........tell me what you think
  197. 400 block + 350crank = 377 Can anyone tell me anything about them???
  198. High rpm studder/miss
  199. adapting heads
  200. Rebuild every year due to billet connecting rods!?
  201. Custom intake manifold, where to start?
  202. wiring to the tack, need help
  203. Power Brakes and Steering
  204. Optimal head flow numbers?
  205. 120 fuel comp
  206. How to test fuel pumps for flow at home?
  207. Does cubic inches affect optimal cam intake centerline?
  208. 355,383,396 effeciency per cube?
  209. Combustion chamber size
  210. Viper T-56?
  211. ceramic coating ??
  212. Valve Cover Spring Oilers
  213. Z06 MAFf use on a LT1
  214. 18 Degree Topend FS if anybodys Interested
  215. Any progress on the OPTI alternative
  216. A discussion I had with my tranny guy
  217. Loose crank pulley!!! What damage could have been done???
  218. 108 LSA on an LS1?
  219. Rearend experts - humm or gear noise
  220. E-brake and Ford 9"
  221. Largest injectors that can be driven by PCM?
  222. swaping in a th400
  223. TH400 No Pressure in Drive...
  224. Seasoned versus New Aftermarket blocks?
  225. Advantage of low CR/high boost?
  226. Where can I get stock rod bearings for LT1?
  227. Compression Ratio VS. Fuel Octane
  228. Stroker Motor
  229. Spinning alternator the opposite way: How to cool?
  230. PLEASE help!! 2nd trans in 2 weeks!! What is wrong??
  231. Pro Performance?
  232. Valves and cuts, tulips etc
  233. Turbos
  234. LS1 in an LT1 f body...
  235. offset gound crank
  236. compression ratio question
  237. Any interest in a tunable MAF?
  238. Tranny rebuild at Cottman transmissions? Please read
  239. Best heads? TFS, Victor Jr, or AFR?
  240. Persistant Oil Leak
  241. Underdrive pulleys and water pump
  242. Engine about to go?
  243. 110 vs 112 LDA?
  244. Puzzled over high exhaust temps
  245. Valve jobs altering angles gains of 18 cfm?
  246. code P1351 anybody?
  247. Intermittent Code 43.
  248. 383 Carb Swap
  249. 700r4 ? slow 2-3 shift @6000
  250. Question about 2 oil pumps for a Turbo car....
