Engine Building Checklist SBC
Old Aug 30, 2003 | 05:14 PM
Nitromethane's Avatar
I'm lookin for a complete check list of every clearance you should check on a race-spec motor, as well as acceptable range of clearance, I don't wanna forget anything and don't intend to rebuild this thing for another 2+ years
Also, any tips on how to check the rod to cam clearance? Which rods are prone to hitting the cam? I think its only on 2 cylinders that you need to worry but I forget exactly. I'm using H-Beam's that are profiled for stroker applications without needing a small base circle cam, but I wanna make sure anyway.
I wanna know piston to valve clearance, piston to cylinder wall, a good way to check camshaft "walk" as well as acceptable range for that on a solid roller cam, basically I need the check list that a machine shop charging $1000-2000+ to build the motor would use.
I don't usually turn 7500rpm in my motors so I wanna get this absolutely right.
Old Aug 30, 2003 | 09:19 PM
menlatin's Avatar
i think there is an engine blue printing book for like $15-$20 on amazon.com. I would think that would alot of that. possibly right here
Old Aug 30, 2003 | 10:20 PM
Thanks didn't even think of a book I've lost patience with the guy "building" my engine, the only reason I was gonna pay for it is because he owes me money so technically im not paying for it in cash n I didn't have the patience to check all the clearances n re-assemble everything 3 times.... but its been 3 weeks since he said he'd build it so I'm getting impatient
Old Aug 31, 2003 | 09:02 AM
Closing thread.
transam_388
Mar 15, 2015 11:53 AM
Jrlt1
Jan 3, 2015 07:38 PM
Bearmans
Dec 3, 2014 05:28 AM
squirrels
Jul 13, 2002 01:58 AM
