T-56 swap to Turbo 350 Transmission
I need some help with a few questions
I'm right now building a turbo 350 trany to put in my 95 z-28
I'm using fairbanks fiber clutches and stripe shift kit and I have all the harden parts that have been recommended to me by the transmission shop to handle everything I can put to it.
1. Have anyone tried putting a turbo 350 in the newer camaros? if so what was the results? I'm looking for better ET at the strip.
2. The turbo 350 I have is a Long tail. I was told its the same length as the T-56. is this so ?
Before anyone asked the reason I'm not using a 700R4 is that they are not able to handle a lot of abuse without dumping a couple thousand dollars in them. I also know that gas mileage is going down the tubes. If I was worried about gas mileage I would not be building it.
Any feeback would be great
Tim
Tim
Unless you have a relatively light, relatively low power setup you should not use the TH350 but get a TH400. Heavier, will absorb a few more hp, but much stronger. In the same vein, unless you have a high-po setup, you may be slower (though more consistent) with an automatic than a manual. Of course, you may know all this. But in case you don't, I wanted to help you avoid a mistake.
Rich Krause
Rich Krause
I have a TH350 set up and a TH400 set up with trans brakes, cheetah shifter, etc I would be intersted in trading for your T56 Let me know, my email is bubblemailer@excite.com
hey a long shaft 350 12" shaft will require cutting driveshaft overall length is 33 27/32, 9" shaft is 30 11/16, 6"shaft is 27 11/16, a 4l60e overall lengthis 30 3/4 so hopefully you have the 9" tailshaft hope this helps Andel
james007moore
Jan 1, 2016 01:14 PM
