PDA
View Full Version : Advanced Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18
  1. Auburn differential
  2. Advanced 12 bolt and ABS question
  3. modeling the dynamics of valve springs
  4. stock gm roller cam setup in old block
  5. i found homemede flowbench directions
  6. Tranny acting up after shifting to 3rd.
  7. stalling problem
  8. Head conversion
  9. Valve Throat Diameter
  10. Solenoids
  11. Need rearend advice BADLY!
  12. problems adjusting valves. help!!
  13. Test Opti??
  14. Piston to Valve clearance
  15. Torque Arm Conversion! HALP!
  16. camshaft experts, timing experts
  17. Relocating alternator......Pulley question???
  18. valve to piston clearance
  19. too much overbore!
  20. "Signatures"..... there is a limit
  21. Wits end with brake problem
  22. THe lifter wont go int he hole!!!
  23. Whats the best method for fixing dings in piston face?
  24. Can i re-use a graphite style headgasket if the motor hasn't been fired up yet?
  25. Question related to valve size options
  26. 977/978 springs, Hydra-Rev question
  27. T-56 Rear bearing
  28. Cam Button Material
  29. high hp+spray+m6 Q's
  30. Fuel injection cam versus carbed cam
  31. What is the formula for?
  32. Blower HP different than NA HP??
  33. torque converter
  34. Need help with static cr for 383 build-up
  35. Duramax Diesel 32 valve heads on LS1?
  36. 396 cam options
  37. New ZZ383?
  38. Chassis Dyno vs. Engine Dyno
  39. Cast Crank + Fluidampr vs. Forged + Stock H.B.?
  40. fastburn385?
  41. hypereutectic vs. forged?
  42. HELP! Anybody recognize these rods?
  43. LT1 block/SBC Crank Mismatch?
  44. Target A/F ratio????
  45. SB1 in 4th gen
  46. Head Gasket question
  47. Rev Kits? Advantages/Disadvantages
  48. AFR 210vs220vs227
  49. Say, you know how those restrictor plates...?
  50. Cylinder Head Casting #'s HELP ASAP ! AND CAM Question
  51. Blower Camshaft Selection....Need Help!!
  52. Steering column lock/key assembly removal
  53. water injection with high compression???
  54. Stroker rotating assembly question
  55. Best way to check P o V clearance?
  56. converting head flow numbers- 25"-28"
  57. BBC Crank Snout on Blown LT1
  58. Cam question (Nitrous related)
  59. Advantage or DisAdvantage of 1.5 vs 1.6
  60. hub compatability
  61. Head studs ???
  62. Comp 987's with out locators?
  63. 12-bolt rear widths
  64. Small & remote vs Large incoil cap HEI
  65. 64cc VS 70cc Combustion Chamber
  66. is the stock crank a few degrees advanced?
  67. balancing question
  68. Blower, Pistons and Cam - can I?
  69. standard tension VS low tension oil ring
  70. Vortec V6 vers non vortec heads and engines
  71. TPIS ZZ409 Cam
  72. Solid roller set up
  73. What to look for when tearing down motor?
  74. FlowBench Comparison
  75. Question about Rod Length.
  76. sbc gm vortec heads
  77. H-beam rods? please help
  78. cam/con rod clearance in a stroker
  79. Solid vs hydraulic
  80. Variable Valve Timing vs. Chevy OHV SBC
  81. LS1 alum blocks
  82. Nice thread
  83. Main cap bolts
  84. Would there be a problem with making a 350 block stroker .040 or .060?
  85. carb intakes
  86. Anyone put an LT5 in an F-Body??
  87. Switching from LT1 to standard SBC...
  88. .
  89. Rebuilding Questions
  90. ring question
  91. Turbo piston selection
  92. trans go's full manual kit?
  93. Anyone ever built a 302ci LT1?
  94. Can Al Bow tie blocks be used on the street?
  95. CFM #'S with CAI????
  96. SBC in a LT1 f-body - making the LT1 PCM work...
  97. *Complete* 355 Builds from scratch
  98. intake lt1
  99. Power steering adapter fittings??
  100. Which oil pan with 2pc block??
  101. Got a problem with my AFR guideplates...
  102. Cross Ram Manifold Porting
  103. What solid roller cam lobe profiles are their?
  104. Roller Cam
  105. Odd accessory belt routing question . . .
  106. cylinder liners for LT1
  107. What are the do's and don'ts when attempting valvespring replacements
  108. Installing MSD Distributer in LTt Intake.
  109. Ceramic Coat exhaust valves and pistons
  110. Rev kit.. comp r lifters.. question
  111. Fuel system for stroker motor
  112. Transmission experts
  113. Allison 5-Speed auto.
  114. I need suggestions on what direction to go with my fuel system
  115. Block filler ?s
  116. Optimum rod length for alcohol fuel
  117. Indexing Spark Plugs
  118. cutter for venturi/throat on valve job
  119. clearancing for sbc 383 stroker
  120. LT1 overbore question
  121. Quick head porting question
  122. replacing axles?
  123. help with desktop dyno.
  124. vortec heads and manifold
  125. 3100 series cam lobes
  126. Solid Roller Question
  127. Is this cam too big for a stock bottom end... valve -> piston clearance...
  128. Is there a 'rule of thumb' for determinging appropriate shift points?
  129. Eagle Cast Crankshaft
  130. Controlling aftermarket injectors with factory PCM
  131. What to look for in heads for blown motors
  132. 30lb injectors with stock programming
  133. Engine Building/Rebuilding/Suspension
  134. Piston to valve ?
  135. has anyone swapped rear diff gears themselves and used a solid pinion spacer?
  136. possible to change firing order?
  137. Solid roller guys, what springs and pressure you running?
  138. Those of you that are interested in an updated T56 output/mainshaft...
  139. K-member lightening/ Where are the stress points?
  140. Any Guru Engine Builders here? Kinda Long
  141. Analyze this (datamaster log)
  142. I've got some odd torque converter questions.
  143. Less compression height v. increased deck to lower CR?
  144. What all is involved going to a crank trigger and eliminating the Opti/
  145. Which should I balance my rotating assembly with?
  146. ??? about the new 5.3 & 6.0 motors
  147. Question regarding cranking compression
  148. 4L80E Swap
  149. variable cam advance timing?
  150. terminal horsepower
  151. t-56 race gears
  152. humidity and detonations
  153. Pistons: Do they need to be matched perfectly gram for gram?
  154. Determinant of Top Speed?
  155. Destroked 350 to 302 bottom end.. Would this work?
  156. eliminating Stock PCM ? Is it possible
  157. Power searing cooler
  158. offsetting crank
  159. problem keeping the rr's adjusted
  160. Fuel system experts help please
  161. Ring seal/leakdown and oil usage discussion.
  162. anyone used hardened axles in a 10 bolt?
  163. Direct Fuel injection - anyone?
  164. Speed Pro Hellfire rings
  165. can't start car
  166. Identifying problems by analyzing dynographs.
  167. asking for some advice on engine swap
  168. Odd Buildup Question (305/334cid) Inside
  169. coolant blowing out of my exhaust tip, cracked block or head gasket??
  170. low RPM torque moster vs high RPM screamer
  171. Silent Muffler? Such a thing?
  172. Mr. Horsepower!
  173. Why is drivetrain loss a percentage???
  174. EFI info from a master>>>
  175. I need some perspective on flow #'s
  176. At what duration # do you use to calculate overlap of a cam?
  177. Turbo talon
  178. 4L60E manual valve bodies?
  179. th300 to 5 speed manual in a 67
  180. Hot Rockers
  181. Need help w/ 383 crank info.
  182. Big block lobes on a small block cam
  183. have rotating assembly for high compression 396ci, can I change to low compression???
  184. Question for the handling experts
  185. F.A.S.T. vs Gen. 7 DFI???
  186. Maximun hp for a cast Scat 383 crank-bearing clearance
  187. How to tell if my POSI is bad......
  188. What Manual Tranny?
  189. 383 small block?
  190. Question about cam i made up on desktop dyno. valve timing?
  191. What Tranny?
  192. Air to fuel ratio
  193. Electromotive SDI on but now code 42.. Injuneer??
  194. Throttle body size
  195. Lift vs Duration
  196. buliding a 355 or 357, need imput
  197. Electromotive SDI: To use or not to use; that is the question.
  198. edelbrock performer rpms
  199. .609 lift with .600 lift springs?
  200. valve float?
  201. total seal rings work
  202. Opti-Update
  203. front k member
  204. Overlap and effects on idle quality?
  205. New 8.1 liter EFI, will it fit?
  206. Lets talk fuel
  207. 409ci stroker rod length
  208. Shaft mounted rockers
  209. Can VE go over 100%?
  210. measuring push rod length
  211. E*motive SDI... cam ?
  212. solid roller wiht stock heads (LT1)
  213. Valvetrain Geometry problems?
  214. tunning with wide band O2 without a dyno?
  215. Effectivness of ram air
  216. Tranmission
  217. Think I have to much timing?
  218. 377 stroker
  219. Cats Glowing Red...HELP!
  220. Decked SBC .025 = ? Shim for Dist.?
  221. cam theory question...
  222. Balancing 383 or 396 with one piece seal
  223. assembly lube
  224. LS1 Combustion Chamber Discussion
  225. wieght reduction mods
  226. cylinder head springs
  227. T56 in a 72 vette?
  228. Can i put a th400 from a 1990 chevy truck in my car???
  229. "o-ringing"
  230. Guys with FAST?
  231. too much compression?
  232. XE 3100 lobes, will engine rev lower?
  233. Aftermarket oil pump drive assembly?
  234. kmook.....any luck?
  235. Older 350 CI into 93-95 Camaro swap...
  236. Given a 350 block what exactly do I need to make a 383?
  237. T56 3-4 synchro problems (long)
  238. methodology behind sizing an intake port, OEM
  239. New MSD ignition?? could this work
  240. 4 Bolt main & Splayed 4 Bolt main??
  241. honing?
  242. AFR Head Flow Numbers (Ported) ??
  243. NOTICE: What this forum is for, and what it is NOT for. PLEASE READ!
  244. 383 stroker
  245. converter, size gear for bracket and street
  246. #993 Heads
  247. Gearing selection re-re-revisited... :)
  248. GN powered 1995 Camaro!!!
  249. Break in...
  250. compression calculation
