Ignition signal electrical question (waveform)
Old Aug 10, 2003 | 10:38 PM
Chris B's Avatar
Just wondering if anyone happens to have put their ignition signal on a scope / knows what it looks like. If so I have a couple of questions -
1) I am assuming the pcm ignition module handles the dwell control - so the signal from the pcm to the ignition module is just a square wave, and the ignitor triggers off what, the rising edge?
So assuming I intercepted the signal between the pcm and ignition module I don't need to worry too much about the Ton time (again, assuming the pcm doesn't do dwell control, but the ignition module does).
2) With an 8 cylinder ignition I am going to see RPM / 15 ignition events per second ? So rougly a 60-400Hz signal (700-6000 rpm)?
3) Are there any discrete components that would let me phase shift in the negative the rpm waveform in response to an input (voltage/frequency/current, etc.) For example in response to a varying voltage input I could achieve a larger negative delay (timing retard) for a larger given voltage input?
Or am I going to need to look at a uC to do that? I have an atmel SDK500, I just need to take the time to learn how to program it - and I have the rest of my circuit mapped out in discrete components except for that part.
4) Any other gotcha's, etc. I need to look out for trying to get a timing retard on the ignition pulse circuit (I guess EMI is an issue under the hood, etc.)
Thanks,
Chris Bennight
liamcg97
Nov 25, 2019 05:55 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Injuneer
Dec 15, 2014 09:36 AM
guyomatic
Sep 11, 2002 02:11 AM
