hi-pressure z-28/lt-1 oil pump
Old Aug 24, 2003 | 04:33 PM
jgeorger's Avatar
I need to get a new oil pump for my new stroker and I've seen the stock pump with the white bypass spring is the way to go for a stock oilpan. But since I need a new pump I was wondering if the GMPP PN 12555884 hi-pressure z-28/lt-1 oil pump already includes the white spring.
At the gmgoodwrench.com website they this about the white spring (PN 3848911):
"Used in high-performance oil pump P/N 3848907. Minimum recommended oil pressure for off-highway use is 65 psi at engine operating speed."
However I cannot find P/N 3848907.
Any clarificaton?
Thanks....
Old Aug 25, 2003 | 08:56 AM
jgeorger's Avatar
Or should I just go with the Moroso anti-cav pump I saw in another thread? I assume the stock pickup will work with it.... Also, what about the bypass spring? Is it comparable to the "white" spring? If not, do I get the white spring or shim the one it comes with? Where does one get these shims?
Thanks,
Joe
Old Aug 27, 2003 | 03:19 PM
chesee48's Avatar
yea i have a 383 going in too,,.,
i'd like to see whats a good one to get?
Old Aug 27, 2003 | 03:28 PM
WheelmanZ28's Avatar
Canton makes good oil pump/pickup parts for LT1s. They are designed with the the higher volume/pressure that a stroker motor will produce.
You can check them out in the Lower Engine section of www.ls1speed.com
Old Aug 27, 2003 | 03:54 PM
chesee48's Avatar
ty ryan
Old Aug 28, 2003 | 11:19 AM
jimlab's Avatar
I bought the Canton pump and pickup to use on my 396, but ended up going with a blueprinted Moroso pump (PN 22112) and the Canton pickup (for my Canton pan) instead at the recommendation of the engine builder.
Old Aug 29, 2003 | 07:24 PM
arnie's Avatar
Re: hi-pressure z-28/lt-1 oil pump
Any clarificaton?
Thanks....
The #907 pump may not be available anymore, haven't checked lately. That pump was equipped with a 5/8" tube as were early LT1s, which is ok, it's just so that you know this goin' in. If in doubt about the #911 spring, get one and compare to the spring in whatever pump you decide on. It will cost you all of 2-3 bucks.
I have found that aftemarket pumps/gears to have better quality machining that oem pump/gears. Again, not a major factor, just FFT.
HectorM52
Jul 30, 2017 11:46 AM
KYWes
Apr 15, 2015 07:11 PM
KYWes
Apr 15, 2015 05:48 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
NEWBIE T/A
Jun 14, 2002 12:27 AM
