Bore size?
Old Aug 23, 2003 | 08:13 AM
1FastRedZ's Avatar
60 over? LT1
Has anyone gone 60 over on a stock block? Is it possible? Safe?
Old Aug 23, 2003 | 01:39 PM
dano73327's Avatar
not recommended
Going past .030 can lead to troubles. The stock blocks arent known for their bore thickness. Besides if you did find a block with thick enough bores to go .060 you would have no room left for future rebuilds. The best idea is to go no larger with the bore than you have to to get the cylinders to clean up..
Old Aug 23, 2003 | 02:21 PM
kmook's Avatar
Advanced Tech Moderator
Here is a good discussion on your topic-
http://web.camaross.com/forums/showt...threadid=39862
That should answer your questions, and if you have more just join into that great thread
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
RobFlag
Aug 29, 2015 11:40 PM
RX Speed Works
Aug 20, 2015 03:40 PM
Dams76
Aug 20, 2015 08:28 AM
