PDA
View Full Version : Advanced Tech
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18
  1. fuel pressure problem?
  2. SR Camshaft Selection Help Needed!!!
  3. Idiot needs help install oil accumulator
  4. Head port/filling
  5. Dry Moly Spray
  6. Suggest a radiator for a 510 BBC in 95 TA
  7. piston question, please help!
  8. main cap conversion
  9. Timing with MSD Optispark and LTCC coil-on-cylinder.
  10. what to look for? Unbalanced motor?
  11. wat does the water pump do....
  12. Oil system for blown DD stroker?
  13. Valve spacing and dowel shift, can someone explain??
  14. Can someone validate this calculation please
  15. .060 over stroker
  16. Reviving an old thread...
  17. I Need Help Now!
  18. Engine break-in oil..?
  19. "Tray" under LT1 intake... needed?
  20. Can someone explain pumping loss to me?
  21. LT1 block prep
  22. help fast crank snout
  23. I want some LS info
  24. valvetrain geometry issue
  25. Balancing Idiot 383 lt1
  26. initial timing on new engine install
  27. ??'s on converting to run E85
  28. seat/open pressures
  29. LS1 throttle body VS LT1 throttle body
  30. Wide band
  31. Torque specs on splayed main caps???
  32. How much does my intake need to be milled??
  33. Cam and valvetrain matching?
  34. Would this help or hurt?
  35. Steped caps or flat?
  36. Accel "short" race plugs
  37. Enlarging/Modifying the coolant ducts on LT1 heads
  38. Oil Accumulator
  39. Nascar engines?
  40. 2-bolt aftermarket mains strong?
  41. dragonslayer and ATI balancer ?
  42. Timing pointer
  43. Transaxle Swap for an F-body?
  44. umm ripped the helicoil out of the head...
  45. OHC vs pushrod
  46. Block decking
  47. Methonal on carbed LT1
  48. Opinions on engine build..
  49. vacuum problem
  50. Valvespring question
  51. heads and cam?
  52. 383 piston problem
  53. Is 2KPA Worth Chasing
  54. motor locked
  55. Viper's variable valve timing w/cam in block engine
  56. Where can I get SAE specification documents without spending $500?
  57. Hi-Ram Tunnel Ram Manifold, good or bad idea
  58. Cfm??????????????
  59. enlarging inside diameter to shorten effective intake runner length?
  60. stroker motor problem
  61. Coated pistons... worth it?
  62. Valve spring oilers.
  63. Head bolt torque specs?
  64. Cylinder Wall question
  65. Head conversion pictures
  66. Traction control install?
  67. A brief discussion of oil pressure, etc.
  68. DCR, Cam timing, and Emissions
  69. [edit] Valve tick won't go away! Lifter preload? (MS4 cam install)
  70. Block Filler
  71. Results of stepped headers/merge collectors vs standard headers
  72. Coated bearings
  73. .050" vs. .006"
  74. Gapless TOP rings
  75. TB spacer
  76. help with casting #
  77. Throttle body options for a single plane
  78. Helmholts and resonation principles in FI applications.
  79. H series on a small fillet crank?
  80. Help Please?
  81. Some Advice on 10:1 please
  82. Vacuum Pump Question
  83. LSA vs. ICL in regards to IVC (Advertised IVC needs 4° adjusting?)
  84. $200 shaft rockers?
  85. help with top end.
  86. Intake closing point ABDC for calculating DCR...
  87. Good Article on Compression & Quench
  88. ramp rate/valve spring ?'s
  89. Wanna see Nascars new LS based engine?
  90. Max safe Compression Ratio for pump gas
  91. Intake backfire ???
  92. Need help calculating DCR!
  93. ballistic engine bearing coating
  94. Top end fpr a serious 383/396
  95. Installed height on springs
  96. 12370844 SuperTruck Engine Handbook
  97. cam gurus: thoughts on this
  98. AFR 227 Valvetrain Parts
  99. Hot Rodding the LS7 - little FYI
  100. whats tha best CR?
  101. horsepower:torque relationship?
  102. Dual throttle body LT1 intake
  103. Head Flow/Intake CC ????
  104. Help computing DCR
  105. Single Plane Tuning
  106. Carbonless Impression Paper?
  107. Beehives direct replacement for 987??
  108. ZZ4 - LT1 intake?
  109. Exhaust Centerline and Header Lengths?
  110. Scat Pro Comp 4340 Forged - 7/16" Cap Screw rods....
  111. pre-load/ lash adjustments
  112. Roller lifters?
  113. OL SD Tuning
  114. Difference between N/A and Blower cam other than LSA?
  115. Bearing ???
  116. Lateral Honing?
  117. Mahle PowerPak question...
  118. Anyone Flowed an Stock LT1 or a Miniram Intake Manifold?
  119. Test block after grinding for 383
  120. Which of these two cams are theoretically bigger?
  121. questions on ramp rate and duration/lift
  122. Oil filter tech
  123. why not?
  124. DCR calculator spreadsheet
  125. How much does elevation affect maximum compression?
  126. Thermostat question
  127. Compression ratio in relation to octane requirements?
  128. Beehive Valve Spring tests..
  129. Sb2
  130. Valve train issues during "storage"
  131. Happy "High Tech" holidays to all.
  132. re-torquing head bolts...
  133. DCR and SCR vs. boost
  134. callies rotating assembly
  135. How bad do Copper Head Gaskets leak on the street for a daily driver
  136. Omnivalves.......thoughts on heavy valves?
  137. Plenum Divider Walls Question
  138. How to tell if Main bearings are gone
  139. Desktop dyno help
  140. Anyone compare the Callies Dragonslayer to the Compstar Comet?
  141. Adding on to a fuel tank..
  142. Questions about BBC heads..and CR
  143. CSA Of Intake Manifold
  144. Intake Manifold Short Side Radius
  145. Trickflows 13 deg valve angle LT1 heads, heard of them?
  146. Piston sidewall clearance
  147. Max headflow acheivable while retaining the 170cc intake port?
  148. colder resistor plugs
  149. Do I need another valve job?
  150. RPM Max????
  151. much debated 383 vs 355
  152. How do you convert .050 duration from 1.5 rockers to 1.6's
  153. what plugs for this 377? help
  154. Aftermarket engine mangement and the 4L60E
  155. Intake Cross Sectional Area Or CSA
  156. Second Gen Oil Pan Replacement?
  157. coatings
  158. Speed Density vs Mas Air vs Collector Leaks
  159. Piston Top Differences
  160. supercharged 383 ci- sprayin .. whats the tricks ?
  161. LS7 Wins.
  162. Target dynamic compression
  163. Tips for locating an intake airflow restriction? Flowbench link within...
  164. pushrod length? pics inside
  165. Bay-to-bay breathing on old Gen1 SBC
  166. can head gasket bore diameter be too big?
  167. Whats the best cam bearing to run?
  168. Engine Masters Challange Discussion Continued
  169. fuel rails for lt1's
  170. 145 mph speedo swap
  171. SOmeone please check my math
  172. Best solid lifter for STREET use and why
  173. SHould my car smell like this?
  174. Looking to build street/strip 355....
  175. New Nascar Chevrolet Engine
  176. P to V clearance questions
  177. reversion of exhaust flow?
  178. Need help. k-member & motor mounts for BBC
  179. whats inside an intercooler?
  180. Which rod
  181. 383
  182. What chamber size?
  183. Heat Treating
  184. How much Alcohol can injectors take?
  185. who the hell makes lt1 cranks larger then 3.75?
  186. help with dcr
  187. properly designed quench region
  188. CHeck my COmpression ratio number
  189. Detonation propensity on a big cube SBC Q?
  190. "How to" stroke a LT1 for best performance!
  191. The last rod ratio thread, I swear!
  192. Shaft mount roller rockers
  193. 383 or 396...the REAL pros and cons
  194. What You Need To Know About CNC Heads
  195. Motor plates or solid engine mounts
  196. Best shop for head/super vic conversion
  197. High temp paint for headers. Any recommendations
  198. headers for F body with 18* heads?
  199. Motor is Done
  200. Amount of rubber needed for 700HP From an Lt1 Z-28 convert.
  201. 8.1 Vortec Cam Sensor In Opti
  202. Muffler Design Questions/Resources?
  203. LT1 motor mount HELP please.
  204. Help with Solid roller setup
  205. rotor button design
  206. Mix of the new with the old..
  207. Header question
  208. Anyone use Brodix heads W/Brodix single plain
  209. Pushrod length
  210. Broken crank whats compairable to cola
  211. Determining Safe RPM for a shortblock.
  212. Fouled plugs making more power?
  213. conversion for mv please
  214. correct a/f
  215. Whatever happened to Jim LaBreck AKA JIMLAB
  216. Injectors bleeding down
  217. no load vs. high load
  218. Valve spring "installed height"
  219. Static compression
  220. Having possible issues with Morel Lifters?
  221. Race gas and O2 sensors
  222. Victor intake for lt1
  223. Large bore lt1 block
  224. Lingenfelter camshafts?
  225. Need H Rod Help
  226. Followed The Miller Mid Lift Principle
  227. EFI on a Buick 455?
  228. LT1 intake plenum increase
  229. Head Bolt Spring Clearance
  230. Hyfire VI-AL ign box? high rev issues
  231. 69 camaro head question
  232. 4.8L crank and rods and 6.0L bore for E85
  233. Notching to Unshroud
  234. Crank balancing
  235. LT1 to run on only E85, looking for information and ideas
  236. Push Rod Flex
  237. LSx built for 105 octane E85
  238. Correct way to measure deck?
  239. Bead Blasting Head Deck Surface
  240. Connecting Rods....
  241. New valve guides??
  242. Valve spring mishap!
  243. Cutting grooves into heads
  244. Sb2.2 ?
  245. NHRA Top Fuel blower belts
  246. effects of offset cam bushing on LT1
  247. Engine Analyzer Help
  248. Trying to match bob-weight.
  249. Possible to use conventional 400 block and build a 377ci LT1?
  250. Dev Tej Kohli - Hi
