Transgo separator plate- and question
Old Jul 25, 2003 | 07:56 AM
Don2's Avatar
Last night I believe I finished my long transmission saga. I am theorizing that the Transgo shift kit I installed in my original transmission is what lead to its early demise. My rebuilds that had this kit installed all slipped in 4th. I even changed to a different valve body and then drilled the fresh separator plate the other day. The problem returned. I finally bought a Transgo separator plate from a transmission shop which has pre-set holes drilled and installed it with all the valve changes from the shift kit. My problem is gone and now the transmission finally shifts crisp and strong. My guess is that my instructions have incompatible hole sizes for whatever GM Goodwrench rebuilds have for separator plates. This is the type of the two separator plates I used initially. This also leads me to a question. Has anybody else installed the Transgo shift kit on a Goodwrench rebuilt transmission ? Any comments or suggestions on what may have been happening?
Victor Lamb
Aug 26, 2017 02:52 PM
Magenta_Hearts
Mar 29, 2017 08:54 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
Wilson
Jul 21, 2002 05:08 PM
Wilson
Jul 21, 2002 04:58 PM
