4 bolt splayed & oil dipstick
Old Jun 23, 2003 | 07:57 PM
jgeorger's Avatar
I'm on the cusp of going ahead with my 383 stroker blower motor. My engine builder is recommending 4 bolt straight mains vs splayed. He claims the splayed interfere with the oil dipstick (happened on a customer's car).
Also, is $700 a reasonable price to do this conversion?
Old Jun 23, 2003 | 08:20 PM
Ai's Avatar
Ai
You may lose the dipstick with the splayed caps. I just machined my block yesterday for some 22deg Callies caps and it definitely looks like it'll interfere. I haven't really spent any time looking for a solution (aside from straight outers) though,.. I don't need it, I'm just plugging it up.
Regarding cost, I guess it depends exactly on what is included in that $700. Most of what I've messed with has been aftermarket stuff (bowtie/rodeck/etc.) and I hadn't ever had to convert a production 2bolt block before. It took me probably 2-3hrs to complete it, so I'd probably charge $225-250ish for the machinework alone (~$75/hr). You'll need to have your stuff align-bored & obviously honed afterwards...
Dunno, depends on what all he's doing for $700 : )
Old Jun 23, 2003 | 08:40 PM
jgeorger's Avatar
That includes the caps, the align bore/hone, and labor (everything, AFAIK).
Old Jun 23, 2003 | 09:01 PM
Eric Bryant's Avatar
I retained the dipstick with my splayed Miloden caps and Canton pan, but I had to cut off quite a bit of the dipstick tube. This didn't seem to cause any problems.
$700 seems a tad steep. My caps were $200, the ARP studs were another $50, I machined the registers and drilled/tapped the side bolt holes myself and left the line-boring/honing to the machine shop who charged $275 for that task (I think their normal charge is $325 if you have them machine the registers and drill/tap the holes).
Old Jun 24, 2003 | 05:56 AM
Diptstick still functioning with my ProGram splayed caps.
Old Jun 24, 2003 | 09:09 AM
Brady's Avatar
My dipstick works fairly well with the milodon caps. I paid $500 for the conversion.
Old Jun 24, 2003 | 09:38 AM
95 Silver TA's Avatar
What kinda caps are you thinking of going with, I have Oliver Caps on mine and all I did was took two plyers and flattened out the end of the distick tube a little (the part that curves at the tip) and it fits real well now. No interference but when it had the little curve in it, it would hit the Cap pretty bad now with the curve/swirl flattened out, its completly fine.
Hope that helps,
Claude
Old Jun 24, 2003 | 11:53 AM
jgeorger's Avatar
Was that without any modification to the tube?
Old Jun 24, 2003 | 12:24 PM
Rob(94Hawk#319)'s Avatar
We had to flatten my dipstick (that sounds really painful.. ) to clear with the mains and Canton. But it works fine.
________________
Rob
1994 Firehawk#319
11.83@120.61
Slightly Modified
1996 Blown V6
2002 Trailblazer
San Diego F-Bodies
"Kill a man, and you're a murderer, kill many, and you're a conquerer, kill them all, and you're a GOD!"
Old Jun 24, 2003 | 01:13 PM
Mr. Z28 73/97's Avatar
Get the GM billet splayed main caps $50 ea from scoggin dickey and the dipstick clears just fine.
Old Jun 24, 2003 | 04:07 PM
jimlab's Avatar
Same here. I'm using a Lokar flexible dipstick, Canton pan, and Pro Gram/Oliver caps. Here's a picture of how close the 4-bolt cap is to the oil dipstick hole.
http://home.gci.net/~jimlab/images/B...d/PB140024.jpg
I paid about $500-550 for all 5 caps and about $225-250 for the machining, if I recall correctly.
Old Jun 24, 2003 | 04:14 PM
I have the stock dipstick tube, and it is rotated out away from the block to clear the headers on the outside. I honestly can't remember if the tube need to be cut.
Old Jun 25, 2003 | 10:17 AM
TonyJ's Avatar
Damn, Jim... That's one incredible engine. I took a look at some of the other pics and all I can say is WOW!!!
Check out this one boys...
http://home.gci.net/~jimlab/images/E...pecial_lt1.jpg
Old Jun 25, 2003 | 12:00 PM
.....**in awe**.... Beautiful engine, beautiful intake. Is there some more info on that intake?
________________
Rob
1994 Firehawk#319
11.83@120.61
Slightly Modified
1996 Blown V6
2002 Trailblazer
San Diego F-Bodies
Old Jun 25, 2003 | 12:51 PM
jimlab's Avatar
$2,850, with nitrous bungs installed.
http://home.gci.net/~jimlab/images/Intake/
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
