figuring converter slip from dyno figures
Old Sep 8, 2003 | 02:30 AM
Chode89's Avatar
My question is just as the subject line is asking. Can and how do you figure torque converter slip from dyno numbers? Can you tell if your converter is too loose? Thanks for your help and advice.
Old Sep 8, 2003 | 08:25 AM
Have them do a plot with HP on the left vertical axis, MPH on the bottom horizontal axis, and RPM on the right vertical axis. If you know your tire diameter (remember, its on a chassis dyno with straps holding it down and limiting tire growth (another factor to consider), you can convert MPH to axle RPM to driveshaft RPM, and compare it with engine RPM. The difference is slip. If you get the numerical printout for this plot it makes it easier to set up a calculation sheet.
Old Sep 8, 2003 | 09:19 AM
OldSStroker's Avatar
Originally posted by Injuneer
Sprung from cages out on Highway 9,
Chrome wheeled, fuel injected,
And steppin' out over the line.
Ah yes, gotta love The Boss.
Old Sep 8, 2003 | 10:15 AM
Chode89's Avatar
Thanks, that was easy. Now just hope they send the file so i can change the chart.
Old Sep 8, 2003 | 10:41 AM
Specially when he shops in your local Barnes & Noble, and when you have actually driven/raced on that "Highway 9"
jer4251
Sep 21, 2020 09:42 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
AlaskaZ28
Apr 17, 2015 08:54 AM
ChrisFrez
Feb 15, 2015 07:49 AM
smokin25th
Jan 1, 2015 09:06 AM
