Torque specs for Eagle H-Beams?
Old Jul 26, 2003 | 04:25 AM
Mullet Z28's Avatar
Sorry, this is one of those "no one in LT1 Tech knows" questions.
They're the "3D ESP" H-beams with standards rod bolts (not L-19). I don't have the sheet that tells you the torque specs.
How many pounds of torque with ARP moly lube? How about with 30wt. oil?
Old Jul 26, 2003 | 08:02 AM
Joe Racer's Avatar
63 ft lbs w/ ARP lube
Old Jul 28, 2003 | 09:17 AM
Fickle's Avatar
Re: Torque specs for Eagle H-Beams?
Something more important than torque spec is bolt stretch. You need to contact ARP? and get that stretch factor for those rod bolts.
At the least, you should use lube and torque the bolts down to the spec torque 5 times.
Old Jul 28, 2003 | 09:40 AM
Joe Racer's Avatar
Bolt stretch is .0059-.0063
I would have included that in my earlier post, but assumed most individules aren't able to acurately measure bolt stretch.
Old Aug 1, 2003 | 02:53 PM
Mullet Z28's Avatar
Thanks fellas.
MDZ28
11
Sep 24, 2015 09:15 AM
Bxlt1
Sep 17, 2015 08:31 AM
Daluchman1974
Sep 11, 2015 06:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
94ZinEdgewater
Sep 8, 2015 09:55 PM
