PDA
View Full Version : Advanced Tech
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18]
  1. Calculating CFM Question (NOT GENERIC)
  2. cementing bottom 1/2 of block???
  3. Removal of abs system
  4. Is David Vizard on target for LT1 Heads?
  5. Factory OBD1 PCM limits (again)
  6. New here and really in the woods with Flywheels..
  7. Opti Question
  8. calculating overlap?
  9. intake/exhaust flow % question
  10. LT1 Victor Jr. heads
  11. Yo.......
  12. LT1 Intake Manifold Flow
  13. Cast 383 Crank experiences? - Good and Bad please....
  14. Big valves, small bores, and a lot of boost....
  15. Smaller TB....more power?
  16. What's do you think about David Vizard's 90's head porting book???
  17. Can anyone make a 4L60E live?
  18. Those with ported heads, enter hear.
  19. Where to get a custom ring and pinion set?
  20. 16v conversion (usually race only)
  21. Working on the Opti solution.
  22. Multiple Fuel Pumps (Injuneer please comment)
  23. Fuel flow vs. HP
  24. Arao 4-Valve Heads
  25. Took apart T-56...made a mess
  26. Benefits & Disadvantages of various temp thermostats on engine performance
  27. Define EGR and it's effects
  28. The infamous obd1/high stall converter problem
