Advanced look at Strut Tower Braces
Old Jun 20, 2003 | 02:04 AM
atljar's Avatar
First and foremost, let me first say that i have an adjustable strut tower brace on my car. When i installed it the front end felt tighter, but SOTP meters are never right IMO.
Some points:
The front strut towers are made from very thick solid steel. Anyone ever notice when f-bodies wreck, no matter how hard they are hit, those towers will not give. I have seen that ring true many times.
I jacked the car up the other day from the side, in fact i had the entire passenger side in the air, while the drivers side was taking all the cars weight. I loosened the bolts on the one side of the STB, and marked the base off with marker. Then i let the car drop quickly down, and the STB and my lines didnt budge.
Has anyone performed skidpad test in the same conditions with and without the bar? Or a longshot, maybe put a spring scale between the towers and see if any force is applied?
I almost wonder if this mod that many advise, is all hype? The bar is also a PITA to work around too. Any real world views or test will be welcomed!
Old Jun 20, 2003 | 05:38 AM
I think we're getting away from the guidelines for content on Advanced Tech, which is supposed to focus on engine and drive train. I guess we've already solved all those problems, and need to start looking at brakes and chassis...... .
My first comment would be to call it what it is on the 4th Gens.... a shock tower brace, and not a strut tower brace. Then I would suggest that it be posted on the "Auto-X...." forum, because I think it has been discussed extensively there, particularly with regard to whether it provides any benefit. I recall a thread where they were regarded fairly negatively, for providing a more severe, less forgiving transition when the body was pushed to its limits..... but that's a vague recollection.
Old Jun 20, 2003 | 12:33 PM
atljar's Avatar
Fred-
Thanks for not moving this. You always seem to get much more responsive and helpful answers in here.
I searched over on the AutoX forum and only came up with one informative post, which was on 2pt vs 3pt braces. You dont happen to have a link do you?
Jared
Old Jun 20, 2003 | 12:41 PM
I'm sure it was more than a year ago.... I think the complaint was that it made the chassis more susceptible to sudden breakaway on extreme cornering, and that some "flex" in the front end was better...... but I can't remember the details..... my car doesn't go around corners any more .
I always felt the front end had a more solid feeling with the brace, but its hard to quantify, or prove. I was surprised how much the chassis flexed even with a roll bar, SFC's and my 3-point STB. I had the front wheels on ramps and jackstands under the rear subframes, and the car was level. It had been sitting that way for about 2 months, and I went to pull the pin out of the driver's side swign-out bar, and it wouldn't move. I eventually manage to pull the pin out, and then couldn't get it back in. I couldn't understand how the car, supported level on all 4 corners was flexing so much. When I went to pull it off the ramps, I realized the passenger side front tire was flat, and that misalignment was what had caused the chassis to flex so much. I put air in the tire, and the roll bar pin slipped smoothly back in......
Old Jun 21, 2003 | 07:49 AM
LT1 1980 malibu's Avatar
Trying to keep this simple, roll bars help stiffen the chassis yes..Improve structual rigidy, no..The problem will lay in teh unit body assembly..Effective in its own right it proves to way ahead of the old well know ladder type frame..Ever see a hard launching G bdoy like a malibu with a stock frame cutting a 1.5 60ft..Pretty funny how the front clipp will twist and wiggle..I have actuall had a G body frame bare on it side and wobbled it like a piece of cardboard before i worked it..Here we move to the unit body..Industry terms it as a unit when refereing to it since it is made from many parts..To make it fast and cheaper to build its spot welded together..primraly made from thin ga steel that will flex on its own but together along with other parts does a fine job of holding the car together on the wheels..Add a roll bar that has been proerly installed you do make it stiffer but in between your attachment points of your downlegs and main hoop you still have that old somewhat flexy stamped steel.When i attach my main hoop i try my best to either tie into the rocker panel with the main hoop and door bars or at least install out riggers.Another problem that a unit body has is teh floor area is usually the weakest piont in the whole car.Roof panels and the rocker panels are not that strong and the firewall and rear shelf is called upon to box all this up..Not much when you think about it..Thats why you see many a new cnvertables with a hydroformed rail inside the rocker panels..Cryslers sebrings and the germans do this..(real fun cutting through it with a saw zall or chop saw )
Enter the strut tower brace..With front suspension affixed to the front crossmember and its job to support the engine its made from heavy thick material..But it cant lessen tornsional loads but itself to well, afterall its on the bottom only..Add the strut tower brace up top and then it gets help..This will make the car feel more stable over the road and the bumps and so forth that used to flex the hell out of the front of the car or back if you have one out back stronger..Think of it like boxed LCA's but in a larger form..The problem that really good drivers experence is that it then changes the dynamics of teh chassis, wich would require either a completely new suspension shock and spring settings to get the same reactions as before with better grip or one must relearn how to drive the car.
In my eyes most out there are a watse of money as they arent designed as they should be..To work best the would have to bewelded into the strut or shock towers anyways..GM H body FWDS have the best half assed ones ive seen..No sperical rods ends and the bar is boxed rail..Albiet small and bolted to teh struts.The adjustable units available to teh public do nothing more than preload the chassis in the worst way and still aloow the natural twisting to happen..
Old Jun 21, 2003 | 10:07 AM
WickedFast555's Avatar
I always enjoy your chassis posts LT1 malibu. Stupid question, but which bar is the main hoop? Thanks!
Old Jun 21, 2003 | 02:44 PM
No stupid question man, just people who dont know..
The main hoop is the bar that is right behind the seat and runs up the car to the roof and across..Its the starting point since the whole assembly gets welded to it.
Old Jul 24, 2003 | 11:40 AM
95_RipperZ's Avatar
Well since welding is better I just went out and welded mine on.
Old Jul 24, 2003 | 01:49 PM
predator's Avatar
hmmm interesting information
Old Jul 24, 2003 | 08:42 PM
Eric Bryant's Avatar
This month's SAE mag has a small article on some Japanese-market Toyota wagon, and it comes stock with a strut-tower brace. Interestingly enough, it has a coil compression spring in the middle. The chassis engineer stated that under heavy cornering, it was transfering enough load to the opposite tower and deflecting both which made matters worse instead of better - so the compliance was added and handling improved. Since they still decided to keep the strut tower, it would seem that this means that you shouldn't be shooting for the extremes, but rather trying to find the balance between too much and too little compliance.
Seems like such a bar would be of very minimal use on a vehicle with twin control arms per corner, unless the control arm pivots had a load path into the shock tower.
Old Jul 28, 2003 | 11:50 AM
Flybono, suspension settings..Not suspension components..If you stiffen up the chassis it will most likely react differently..Now im not super road racer but I can tell whats needed to be adjusted on a road race track..The street is way different and the irregular surfaces make it next to inpossible to get a good feel from the car..Make the frame stiffer wiether its in a good or bad way then it will feel worlds better on the street..I learned that years ago when i was slapping 1100 lbs coils under G body GMs.Sure did feel a lot better but the oversteer was unpridictable and down right scary...The last one i built pulled 1.1 Gs with autocross tires and 600lbs front coils..But still the frame was heavily modified to work better..
Thats an interesting find Eric..It seems to be true if you think about it..Unforqunatly aftermarket companys dont have that R&D avail to them..However I wonder how they determine how the springs compliance reacts to the unitbody flex...All teh while taking into account the requirements for NVH (noise vibration and harshness)..
Old Jul 28, 2003 | 11:49 PM
Pentatonic's Avatar
Re: Advanced look at Strut Tower Braces
When you jack up the passenger side of the car, even when it's up all the way in the air, the weight of the car isn't all supported by the driver's side. I would tend to think all you high-tech guys would know such things. pfff
I'm bored and sick with a sore throat, so it's time for me to ramble on.
If you assume that the car is in static equilibrium, you can draw a simple 2-D free-body diagram of the jacked up car (with a view that looks towards the front of the car). With 4 forces: the weight of the car directed down through it's center of mass, the normal force due to the driver's side tire contacting the ground and it's friction force, and the normal force due to the jack under the passenger side.
If the normal force due to the jack is directed perpendicular to the car, that normal force will not be completely vertical, ie. it will be at an angle that is off of vertical as much as the car is off of horizontal.
Assuming the car is in static equilibrium, you can say the the sum of the forces in the y-direction sum to zero. From the FBD, you can see that the normal force due to the driver's side tire contacting the ground is = (the weight of the car) + (the normal force due to the jack)*(cosine of the car's angle).
So if you increase the angle the the car is at, for small angles you are only transferring some of the weight to the driver's side, not all of it. It's interesting to note that if you draw the normal force due to the jack completely vertical, the static equilibrium equations will say the the two normal forces are equal.
A lot of the over-simplified statics and dynamics anlaysis provide only a half-way accurate model of the real-world. Even the more advanced FEA analysis and other advanced computer models sometimes aren't all that accurate.
Old Jul 29, 2003 | 12:04 PM
Dave Feerst's Avatar
Arrrg, you made my brain hurt.
Well. All I know is, I installed my STB and big sway bays along with a PST front end kit 2 years ago. Everyone who drives my car says It handles corners way better than stock camaros.
Just curious, if the 4th gen is a "Macpherson SLA suspention".
That would Imply that the car uses macpherson struts. Now, they arent attached to the spindle like a standard macpherson suspension, but I think they should still be considered struts, not shocks. Mabye I'm wrong. Is there some sore of distinguishing charicteristic I do not know about?
Old Jul 29, 2003 | 04:59 PM
The 4th Gen F-body is not a "Macpherson SLA suspention"... (nor "suspension" for that matter )... it is an unequal length a-arm (SLA) suspension. To me, the differentiator is the number of links in the suspension, and whether the shock also serves as one of the "links". The unequal length a-arm suspension is a "4-link" setup.... the chassis is one link, the upper a-arm the second, the steering knuckle the third and the lower a-arm the fourth link. The shock is not any part of the 4-link mechanism. It serves no structural function.
A MacPherson strut, on the other hand is (I guess you would call it??) a "3-link" setup, and since we all know 3 fixed-length links make a triangle, and can't move, we make one of the links variable in length. That is the function of the shock (aka "strut").... it is the sliding link in a 3-link mechanism. It has a structural function.
To me, that is the difference. The shock on the 4th Gen is "just along for the ride".... so to speak. It is not needed for any reason other than to dampen movement. The true strut on the 3rd Gen is part of the structure and the system can not function without it. It is more than a shock.
The part that seems to confuse people is the "coil-over" configuration of the shock and spring. Just because they are mounted concentricly does not make them a "strut".
Old Jul 29, 2003 | 05:44 PM
huh, thats odd. I remember a few years ago my autoshop book had a picture of a "Macpherson SLA suspension" and it had an exact picture of the 4 gen F- bodies suspension. Mabye it was wrong.
Just acouple more ?s
If you did get rid of the shock you would also have no place to mount the spring. and the spring is neccessary for ride height. So how is that not a neccessary componet?
And how do the upper control arms count as a 4th link to the body. they are mounted the the chassis which is the 1st link to the body. Unless you are talking about the plates above the control arms (are those considered the shock mounts?) but even still. those are part of the chassis that is bolted to the body.
