push rod lenght 7.05 to small??
ok my heads have been milled .30 my block has been zero decked and my piston comes out of the hole .50 ??? not sure if thats right but i have a push rod lenght checker and 7.05 seems to be the right lenght have you ever seen one that small
Re: push rod lenght 7.05 to small??
Rich Krause
its not .50 then they do come out that much but the do come out maybe .05 i cant remember maybe there zero decked i dont know but my push rod lenght is 7.10 on the intake side and 7.05 on the exhust side i ordered the 7.10 i was wondering if these are the right ones
Slow down and try to form you question(s) in a sentence that doesn't require reading 3 times to understand
7.100 does seem kind of short. and .500 is WAY to far out of the bore.. even .050 is too much.. i hop you mean .005
what length valves? if you milled the heads, and decked the block, with stock length valves.. I would guess you would need around a 7.150.
The heads were almost certainly milled 0.030", not 0.300". In that case, your numbers do seem pretty short. Maybe you should have someone else check your measurements.
Rich Krause
my lift on my cam is 520 and my non self aligning roller rockers are 1.6 so i think that my over all lift is ending up being like 560.
I think i could run longer push rod but i kept coming up with 7.10 on the intake i could run the 7.15 but 7.10 keeps the roller tip travel in the center of the valve better than 7.15 but i will recheck again
also I checked the pistons they are flush with the deck surface
i checked it rechecked and checked it again. when i put in the 7.150 its to long when i run the 7.100 it centers it better but 7.20 IS WAY TO LONG almost falls off the tip.
the lifter should not be collapsed at all right??? i just drop in the rr tighten the adjustable nut (with the allen screw out) with my fingers till the push rod cant move up and down any more. then i tighten it 1/8 turn.
i have screwed my checker tool out 6 times it is a comp checker tool 6.800 to 7.800 adjustable in .50 incraments so 6 x .50 = .3 so i get 7.100 dont think im doing any thing wrong
Brandon Wittmer
Dec 7, 2014 12:15 PM
