fuel pump question!!!
Old Jul 19, 2003 | 08:42 PM
2turboz28's Avatar
Angry fuel pump question!!!
i am having some hard times with my fuel pressure. i put an fmu from cartech, bbk afpr, and bigger injectors. when i turn the key on and look at my fuel pressure gauge it reads 65 psi. wtf is that. i tried going back to the stock setup and now it still reads the same. running extremely rich for a while and now it wont even start. it is extremely rich and there is raw fuel and fire coming out of my exhaust when the car actually runs. i really need some help cause this is the last thing before i can drive the car. pleeeeease help!!! thanks
Old Jul 19, 2003 | 09:18 PM
By "going back to stock" do you mean you put the stock FPR, the stock injectors back in, and eliminated the FMU? If so, that would indicate the fuel supply/return system is incorrectly sized, or there is an obstruction in the return line.
-what does the fuel supply system consist of?
-what is the capacity of the pump(s)
-what does the fuel return line look like?
-what size injectors? What is the anticpated duty cycle?
-what is engine HP and estimated (or dyno tested) BSFC?
-what sort of computer is running the engine, and who tuned it?
Old Jul 22, 2003 | 11:42 AM
2turboz28's Avatar
well thanks for the help anyways. i found out that i had a bad fmu. the diaphragm was pinched so it was holding too much pressure. thanks agian
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
RiverMutant96
Jan 30, 2015 09:21 AM
Jessie4tin
Jan 7, 2015 08:53 AM
ANDYZ28
Dec 29, 2014 09:13 PM
