Anyone using DFI, FAST, MoTec ... HELP
Old Aug 21, 2003 | 06:19 PM
bkrepindy's Avatar
Question Anyone using DFI, FAST, MoTec ... HELP
I have finished a complete custom installation of my Gen VII DFI. All of the gauges work, including speedo, exept I can't get the tach to work. When I hook the DFI up to the factory wire for the tach it grounds the system and the car won't start.
It's probably something simple but I'm at my wits end. Is there a factory tach filter I need to disable? Where is it? Do I need a tach adapter? Can anyone answer this?
I don't really want to use a monster tach if I can help it.
TIA
Old Aug 21, 2003 | 06:41 PM
camcojb's Avatar
Are you running any type of ignition box? I just did a Gen VII install on a friends car and the tach wire does not hook anywhere on the Gen VII harness; it hooks to the aftermarket box itself, green wire on the Accel box, spade terminal on a MSD 6AL. This install is on an older Camaro than yours though.
Jody
Old Aug 21, 2003 | 07:03 PM
bkrepindy's Avatar
I was using a Crane HI6, but it is not currently wired in. Do you think I should utilize it?
I think the same thing will happen if I wire the tach to the green Crane wire. The stock PCM just doesn't seem to recognize the signal, and it grounds itself. The tach terminal on the DFI harness looks exactly like that on the Crane box.
Thanks for the reply!
Old Aug 22, 2003 | 12:02 AM
brand-x's Avatar
I had the same problem until I went with the fast track performance wiring harness.
Old Aug 22, 2003 | 09:39 AM
bkrepindy's Avatar
I tried calling them (Mac I think). And no one ever answered, and no one ever called me back. I guess they don't need the business.
Novo
Jun 14, 2016 02:58 AM
football4life
Oct 4, 2015 07:48 AM
MDZ28
11
Sep 24, 2015 09:15 AM
damnyankee36
Sep 9, 2015 07:06 PM
