Running N2O and using OD normally aspirated.
I am still trying to tie everything together on my N2O install. I run 4.56 gears behind my A4. My question is if I run a 100+ shot I will need to use 4th (OD). I plan to use it only N/A as I will flip the switch off before coming out of a locked 3rd gear. Will the OD hold up a few passes if done this way?
I want a 10 second time slip to drool over this winter.
---God Speed, Good Luck and Fast Times to You!---
Kevin Hinkley (HInk) * '94 T/A GT * Best Numbers: 11.952 * 116.83 * 7.566 * 90.51 * 1.579 * Naturally Aspirated 350 ci LT1, No Nitrous, No Blower, No Turbo(s)... Just GOD's good, cold air and gobs of money!
FORMER:
IHRA Bracket World Champion and runner-up
IHRA Bracket World Champion.
NSCA/NMCA EFI Eliminator #6902 Sponsored by:
THUNDER RACING * BMR * DETROIT SPEEDWORKS, INC. * MEINEKE MUFFLER, Jackson, MI. * DISCOUNT TIRE, Jackson MI *
Thank you to all sponsors for your kind help and knowledge!
FORMER:
My Biggest concern would be the Load on the engine using an OD gear. Heavy load could mean Detonation.....
It may be OK......
Kurtis Tamez
LT4-396.com
97 Z28 LT4-396
94 Firehawk LT1-396
Team NW F-Body
[This message has been edited by KTamez (edited August 19, 2002).]
It may be OK......
Kurtis Tamez
LT4-396.com
97 Z28 LT4-396
94 Firehawk LT1-396
Team NW F-Body
10-31-2016 11:09 AM
taner
07-27-2002 06:10 PM
