Any suggestions for taking apart a n2o solinoid and clearing out debre?
Old Sep 1, 2002 | 10:51 PM
JamesN1830's Avatar
Post Any suggestions for taking apart a n2o solinoid and clearing out debre?
I have a NOS n2o solinoid that stays open. I tested it for clicking, and it does click still. I assume it is stuck open due to some debre. Can anyone give me a heads up what to look out for when taking it apart?
James
95 Z28 M6
-355 forged 11:1 motor and Nitrous Works Wet kit 125 shot
Old Sep 2, 2002 | 12:10 AM
CustomN2O's Avatar
Post
You will know it when you see it. Most likely its little debree,that will be stuck in the teflon. Clean it off really good, and hopefully it doesnt leave an indentation on the teflon, and keep if from sealing again.
Old Sep 2, 2002 | 05:23 PM
gb95zconv's Avatar
Post
If the teflon is indented use some 800 grit sandpaper to smooth the surface. Depending on how often you spray this should be done once a year at least anyway.
Greg
95 Z28 conv M6
Georgia F-Body Association
Stage 1 heads, 1.6rr, Meziere WP
lt4 hot cam,lt4 timing chain kit,52mm TB,
Hooker Headers, Pro 5 shifter,3.73s,
NX 150 progressive,
Self-tuned via Tunercat
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jlo
Feb 3, 2015 09:41 PM
Rod Bender
Jan 1, 2015 03:18 PM
Darth Xed
Jul 1, 2002 03:22 PM
