Where Can A Ten Lb Bottle be hidden in a Camaro
Old Sep 19, 2002 | 01:23 AM
JohnsSS's Avatar
I know a ten lb. bottle can be hidden in the spare tire area of a camaro, but are their any other places? Perhaps the other side and remove that black plastic box that houses the 5th speaker? Any ideas...
Thanks.
Old Sep 19, 2002 | 06:42 AM
FRDnemesis's Avatar
Yes it can!!! But I'll Never tell
PS. I am not talking about the spare tire well either(everyone knows that spot)!
I did hear of another on this board speak of seeing one located in the nose of the vehicle however. Thats just a tad dangerous for a street car though.
Jeff
Old Sep 19, 2002 | 09:31 AM
dayusmc's Avatar
From: Stationed at Camp Lejeune, N.C. (But Going Home SOON!)- From New Jersey
I posted it
Do a search by user, under my logon name- dayusmc. I wrote a repley about where to put it and haow to "trick" people in thinking you took the bottle out. I would rewrite it- but it was long. Works great though.
Old Sep 28, 2002 | 10:27 AM
JohnsSS's Avatar
ttt
Old Sep 28, 2002 | 11:19 AM
TheZ's Avatar
why hide the bottle?
i don't hide my 15 lbs bottle
Old Sep 29, 2002 | 01:21 PM
Flyin t/a's Avatar
Yeah what he said, I plan on bolting mine onto the roof of my car. J/K
Old Sep 29, 2002 | 09:52 PM
93 LT1's Avatar
We got some smooth streetracers here?
Old Sep 29, 2002 | 11:28 PM
JohnsSS's Avatar
yep
Old Sep 30, 2002 | 03:27 PM
JohnsSS's Avatar
Any new Ideas or will some of the old work? ttt
Old Sep 30, 2002 | 06:08 PM
kirschman's Avatar
seems like I remember someone removing the pass. side air bag and putting it there, could be wrong though. I planned on going stealth with mine, but, its easy to hide the bottle but the solonoids, w/s, ign. box IMO is damn near impossible to hide. I know ya dont "need" the w/s and ign. but I wouldnt run without any of em. Also if you plan to purge, you can forget hiding that. I know you can have it come out in the inner fender well, but have you ever heard a car purging? Its pretty damn loud!! I guess you could purge while doing your burnout but I've got enough stuff to worry about I just purge on the 1st stage. Also word gets out pretty quick if you live in a small town like I do its hard to get a race for me. If you've ever seen a car run with n2o its pretty obvious if its got it or not, unless it a all out race car IMO, cause usually on a street car unless ya got slicks and a 12 bolt or 9 inch rear you cant hit it right out of the hole, from my experience. Not saying it cant be done, just alot of trouble. But if ya got the time $$ and patience best of luck to ya and keep us posted on how it coming
Old Sep 30, 2002 | 10:17 PM
JohnsSS's Avatar
good though, but that might be a paye in getting the bottle in and out. hmm...ttt
Old Oct 1, 2002 | 02:46 PM
Tucdog's Avatar
Not a stealth way, but how I am going to do mine. On one of the HP shows, they put a kit in a LS1 with T-tops. They cut a 1/2" piece of plywood to fit above the T-top brackets in the back, carpeted it, and mounted the 15lb bottle there. Easy to pop out when you want the tops out.
Old Oct 1, 2002 | 03:22 PM
Flyin t/a's Avatar
Has anyone ever tried putting it down in the trunk and then throwing a set of subs over it?
Old Oct 2, 2002 | 05:22 AM
Skull Leader's Avatar
Lightbulb
Funny you should mention that. I have had that setup for a long time, but now I am also putting an amp rack for 2 amps, but I am having trouble fitting everything down there. Guarenteed to be the stealthiest install ever, none of this stuff with the switches "hidden" in the precious ashtray (it's for SMOKERS like me ).
I put carriage bolts upside down fort the brackets, so there's no big nuts hanging down from the well. You will never see a solinoid or switch or light of any type. I should be all done by the end of this month.
Old Oct 2, 2002 | 12:21 PM
Central PA Z's Avatar
That's what I plan on doing, WHEN.... I get a system. That's the only reason I didn't finish my custom audio setup in the back.
~John
calaban
May 18, 2020 06:43 PM
alphaauto
Jan 23, 2015 07:42 AM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
Dec 4, 2014 11:56 AM
