MSD window switch owners in here!
Old Sep 22, 2002 | 04:16 PM
SILVERZZ28's Avatar
I have just bought a window switch and was wondering if I use it is there any way to bypass when it comes on . Can you just pull the "on"pill out or what? I did read that if you do not want it to cut off that you have to pull the "off" pill out.
Old Sep 22, 2002 | 11:46 PM
kirschman's Avatar
just curious, why would you install it if you plan on by-passing it? Cant answer your ? either
Old Sep 24, 2002 | 11:10 AM
SILVERZZ28's Avatar
Just in case I want to use the nitrous off the line!
Anyone
Old Sep 24, 2002 | 02:48 PM
kirschman's Avatar
Are you auto or M6? Either way you can spray out of the hole!. I spray mine right on the clutch dump if the track is up to par, if not I spray bout 20ft. out. Regardless, I still launch at 4k and higher so I'm always in the "window". Not sure if you're auto, but if ya got the stickies and the track will hold it, stall it up as far as ya can without spinning and then nail it on the last yellow!!
mattstrike
Mar 11, 2015 07:33 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
Speeds8erM-1
Jul 18, 2002 11:36 PM
