What is the best thing to use with nitrous to retard the timing when nitrous is on?
Old Aug 18, 2002 | 10:39 PM
Speeds8erM-1's Avatar
Post What is the best thing to use with nitrous to retard the timing when nitrous is on?
What is the best thing to use to retard the timing when the nitrous is on? I want something that I can drive around with full timing with and then when I turn the nitrous on, it will pull back timing. I was thinking about selling my MSD 6AL and getting a Digital 6 but I was wanting to know if there was a cheaper way with something that will work with my MSD 6AL. I dont want anything hard to use, just something that will pull back timing when the nitrous is on.
1980 Camaro Z28 Sikkens 3 Stage Blue and Purple
1994 Camaro Z28 Teal M6
Ported Heads, LT4 Hot Cam and Springs, 1.6 RR's, Mac Headers and Offroad Y Pipe, Flowmaster Catback, Resonators, Flowtech Cutout, NX 150 Horsepower Shot of Nitrous, NX Bottle Heater, NX Remote Bottle Opener, NOS Purge, KB DD SFCs, BMR STB, Hypertech 160 Thermostat, Redline Water Wetter and Synthetic Diff. Fluid, McLeod Dual Performance Clutch, K&N FIPK, LT4 KM, 1LE Bellow, Holley 58mm Throttle Body, TB Coolant Bypass, Metco Valve Cover Breather, LPW Rearend Support Cover, Strange 3.73s, Eaton Posi, TA Stud Kit, Lakewood LCAs and Adjustable Panhard Rod, LS1 Driveshaft, March Underdrive Pullies, MSD 6AL, MSD Window Switch, MSD Blaster Coil, NGK TR6's, Mobil 1 Synthetic, Pro 5.0 Shifter, Intrax Lowering Springs, BFGoodRich Comp TAs 255/50/16, Nitto Drag Radials 245/50/16, AVS Blackouts on the back.
339 RWHP Corrected with two broke rings
465 RWHP Corrected on the nitrous with the clutch slipping bad and two broke rings
www.geocities.com/speeds8erm1
Old Aug 18, 2002 | 10:47 PM
Z28ROC's Avatar
Post
Me too. But it looks like upgrading the ignition to a dig. 6 or similar is the only way to go right now.
Mario,
White 94 Z28
Yeah I got a few mods
Video
Black 87 IROC-Z
Old Aug 18, 2002 | 11:43 PM
drop top steve's Avatar
Post
I see a lot of msd timing control boxes on ebay....cheap. I have a Digital6, but if on budget a used box saves money.
Old Aug 19, 2002 | 07:38 AM
2094you's Avatar
Post
use the dig 6 .........it has a built in retard the pink wire hook it up to the power source on the solnoid and as soon as you spray it it will pullout as much as you need/want then back ti normal on motor i have it and it eorks great ..
jeff
Old Aug 19, 2002 | 12:20 PM
racer1's Avatar
Post
i use a msd start/retard box from jegs i think it was $150
racer1
lpe heads,intake,mac headers,nos,random torque arm,eibach drag kit,3.73s,slp,callaway honker,sfc,msd,c/e rear shocks,afpr,march pullies
Old Aug 19, 2002 | 12:26 PM
Post
Is it easy to use?
Old Aug 19, 2002 | 03:02 PM
KTamez's Avatar
Post
MSD has a couple different options for add-on ignition retard boxes.
-K
Old Aug 19, 2002 | 03:07 PM
Post
I want something that I can just use to retard the timing when on the nitrous, I dont want anything for starting or anything.
Old Aug 19, 2002 | 11:09 PM
Z28ROC's Avatar
Post
I've heard that the add on retard boxes pull 4 degrees of timing all the time. I don't want to pull timing N/A. Only on juice. Can anyone verify if this is true? That's the only reason why I haven't gotten one yet.
Mario,
White 94 Z28
Video
Black 87 IROC-Z
Old Aug 19, 2002 | 11:25 PM
Post
I dont want that either. I only want it pulling timing when the nitrous is on.
Old Aug 20, 2002 | 12:17 PM
TurboBob's Avatar
Post
http://www.ramchargers.com/cgi-bin/n...890&cat2=26891
I hope the link comes thru ok.
TurboBob
Old Aug 20, 2002 | 12:55 PM
KTamez's Avatar
Post
http://www.msdignition.com/images/pn8982.GIF
MSD #8982
Start/Retard Control
Start retard eases cranking on engines with locked-out timing.
Single stage retard for high rpm or nitrous applications.
Choose 10° or 25° of retard during cranking.
For use on 4, 6 or 8-cylinder engines.
This new timing control is the direct result of MSD being at the races and listening to what racers want. With the large number of engines running locked-out timing, racers wanted a simple way to retard the timing during cranking plus have a single stage of retard available. The start retard provides either 10° or 25° of retard during cranking only. The timing will retard only while cranking and returns to the set mechanical timing once the engine starts and you release the key. Along with the start retard, this new Control also has a single stage of retard. This one retard can be activated in times of nitrous to prevent detonation or high rpm to achieve a little more top end. The amount of retard is adjustable with plug-in modules and is activated by a single wire that can be connected directly to a nitrous solenoid or a micro switch on the shifter. The Start/Retard Control is easy to install and program. It must be used with an MSD Ignition Control.
Start/Retard Control - PN 8982
Not legal for sale or use on emission controlled vehicles.
Old Aug 20, 2002 | 02:07 PM
2094you's Avatar
Post
call ramchargers in madison hgts mi
ask for craig or terry tell them 209racing
and they will take care of you
best thing to get is msd dig 6 it puls timming only when you spray it
plus its a good piece of equipment
to have anyway
Old Aug 20, 2002 | 06:48 PM
BILLJ's Avatar
Post
You can trick the cpu to pull 4 deg of timing out by messing with the ait. When the air temp reaches a certian temp it pulls out a max of 4 deg.(at least on my vette cpu). You have to find out what the resistance of the sensor is when it reaches that. Then have it hooked to another relay that is triggered when on the gas and it will switch over to the set resistor. I think it should be 750ohms. Almost just like the KR bypass swithch.
94 Z28 M6 [R.I.P.] ( stupid stupid snowplow)
97 Corvette. MN6. All the goodies.
00 ZR600EFI Arctic Cat
Old Aug 20, 2002 | 07:49 PM
Z28ROC's Avatar
Thumbs up
Right on Kurtis! that's exactly what I'm looking for.
I've seen it several times, but obviously didn't read the print.
Only $119 from Summit.
