Are there any window switches other than MSD?
Old Sep 15, 2002 | 12:59 AM
mrtravass's Avatar
Post Are there any window switches other than MSD?
I already have an MSD window switch that I used in another system, but I hate the pills and that one pill that you have to turn with a small screwdriver. There has to be something better and easier to use than this out there. Thanks, Travis
Old Sep 15, 2002 | 11:12 AM
RacinLT1's Avatar
Mallory has a digital window switch. All pushbuttons if i remember right.
Never used either 1,so dont have an opinion,check summit or jegs for the mallory switch.
Old Sep 15, 2002 | 01:23 PM
Ed Blown Vert's Avatar
Check out the Mallory Switch. No pills. Fully adjustable,
I got one works great.
Old Sep 15, 2002 | 03:51 PM
speedmiser's Avatar
If you've already got an MSD window switch, then just by one of the MSD rpm dials that plugs into the switch, where the pills would normally go. You can even splice longer wires into the dial lead wires in order to mount the dial some where inside your car, like the dash, glovebox, or console.
http://store.summitracing.com/partdetail.asp?part=628
http://store.summitracing.com/global...e/msd-8670.jpg
Check the Summit catalog. The dials start at 1000-3000 and go up to 10600-12800, and anywhere you want in betwen
Old Sep 18, 2002 | 03:33 PM
It looks like you would need two. Right?
Old Sep 18, 2002 | 04:41 PM
speedmiser's Avatar
Most people just use a pill on the high side. Your high rpm shutoff pretty much stays the same and it's not worth buying a seperate dial. It's the low side you jack with more often, for traction and such.
But yes, to make both the high and the low side of the window adjustable without pills, you'd need two of the *****.
Old Sep 24, 2002 | 02:22 PM
JustaLT1's Avatar
A Question
Can someone please tell me where you would find a Mallory window switch? I can't seem to find anybody that carries them. Thank you.
Old Sep 24, 2002 | 02:37 PM
Loadre's Avatar
Jegs.com Summitracing.com both sell the mallory unit for $219.
Old Sep 24, 2002 | 07:47 PM
MBonZ28's Avatar
http://www.harlan-engineering.com/store/store.html
Harlan window switch is what I use. It uses dip switches to adjust. very nice piece
Speeds8erM-1
Aug 20, 2002 09:12 PM
Speeds8erM-1
Aug 15, 2002 10:07 PM
Speeds8erM-1
Aug 13, 2002 10:24 PM
Redbird
Aug 2, 2002 06:50 PM
Speeds8erM-1
Jul 28, 2002 06:18 PM
