Where to put the Shark Nozzle?
Old Sep 5, 2002 | 07:16 AM
dayusmc's Avatar
From: Stationed at Camp Lejeune, N.C. (But Going Home SOON!)- From New Jersey
Question Where to put the Shark Nozzle?
I am getting a NX kit. I was looking for the best place to put the nozzle. Does anyone know if I can put it right behind the TB under the MAF(at least that is what I think it is) sensor? There is an open spot that looks like I can drill a hole a screw the nozzle right into the manifold. I don't know if my description of where I want to put it was very good. But I am talking about that open spot on the passanger side of the intake manifold right behind the TB. Does this sould like a good location? It looks like it wouls be the neatest.
KYLE-SERGEANT USMC
97 Trans Am with minor mods.
EMAIL: dayusmc@marimecorps.com
Old Sep 5, 2002 | 08:43 AM
1989gta's Avatar
Post
to my understanding the shark nozzle was designed to go minimum of 5 inches or so infront of the tb. You may want to go with a direct port system or call nx on putting it in the intake. You may run the risk of sending more n20 to one or more cylinders by doing this.
Old Sep 5, 2002 | 09:04 AM
dayusmc's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by 1989gta:
to my understanding the shark nozzle was designed to go minimum of 5 inches or so infront of the tb. You may want to go with a direct port system or call nx on putting it in the intake. You may run the risk of sending more n20 to one or more cylinders by doing this. </font>
Good Idea- Thanks!!
KYLE-SERGEANT USMC
Old Sep 5, 2002 | 11:28 AM
drop top steve's Avatar
Post
I machined an aluminum plug for the air duct too replace the silencer tube. Drilled and tapped it for the nozzle, kinda hidden that way.
Old Sep 5, 2002 | 02:06 PM
Fuels94TA's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by dayusmc:
</font>
The best place to put the nozzle is about 4-6" in. front of the T/B. (for proper atomizer for spray) I put mine in the same hole where the IAT sensor went, then relocte the IAT into the airbox very simple just add extra wire and drill a hole to match up the IAT sensor. There is a engine pix on my webpage of the nozzle located in the elbow if you need to take a look at it.
Vinny
http://community.webtv.net/vinnro/VINNYS1994TRANSAM
His[/URL] : 1994 T.A./G.T. NX wet system 100 shot, JBA LT-1 step Headers, SLP LM system, Homemade CAI with K%N filter, Ram-Air caught box under driver side spoiler, T/B bypass, 170 stat, IAT relocate, Jamex stb, Global West panhard bar, Ported & Polish LT-1 heads, Eagle #077 Rims, VST shocks, 4 point Street Bar, Black-out rear kit, 4 point Harness, Autolite #104's, Jet Module #1 with Jet Fan Switch.
Daily Driver- 1990 RS 3.1 V-6 with LT-1 exhaust system.
1970 Project Chevelle 350
Heathen1
Jan 2, 2016 04:27 PM
WildRidez
Feb 23, 2015 07:24 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
NewsBot
Dec 28, 2014 06:20 PM
