Can excessive bottle heat.......
Old Aug 22, 2002 | 10:37 PM
1fastformula's Avatar
Question Can excessive bottle heat.......
Make the Nitrous feel like there is no shot at all??? My bottle is mounted in the hatch(right in the sun), but my back glass is VERY dark. I have a NOS blanket on the bottle and I have been having trouble trying to use nitrous after work. I will hit the button and I feel nothing!!!! WHen I purge it..I get the usual shower of white smoke, but I am guessing that the temp of the bottle is the culprit. I know that 1050 psi is what you want, but my guage cannot be put on until this weekend(gotta get a coupling for the hose)....What are your thoughts????
Later
1989 Formula 350
K&N air filter, air foil, TB Bypass, AFPR (set at 45 psi), A.I.R. yanked out, Accel 8mm wires, Fireball external coil, Pulley (just the crank), gutted MAF, corvette servo, Hooker super comp. shorties, 3" exhaust all the way back, No cats, Flowmaster 40 series muffler (one in one out turned down)---Developed a bad habit....bottle related!!!!75 Shot of Nitrous
http://www.theformulasource.com/owne...php?siteid=144
So they made him get rid of it...For decency ya know....But it came back the next day...
My webpage:www.cardomain.com/id/1fastformula
Old Aug 22, 2002 | 10:47 PM
texlurch's Avatar
Post
yes, too much pressure can cause your nitrous solenoid to not be able to open. I have seen this around 1200 psi. I always use a heavy duty relay and run 10 gauge wire to the solenoids to eliminate any voltage drop. I have also seen this from the solenoids getting too hot due to engine heat, but usually not until they get older...
Texlurch - 68 Camaro-LT1 w/Hot Cam, TT & TIC coming soon!
" a little spray never hurt anyone, spank you very much!"
http://camaroz28.cardomain.com/id/texlurch
Old Aug 22, 2002 | 10:54 PM
Thumbs up
Mine are older.... But I think you are right on the money with the 1200 psi thought!! Which is a good thing I guess...Too much pressure and you run to lean..NOT GOOD FOR THE OLE TPI
Later
1989 Formula 350
Old Aug 22, 2002 | 10:57 PM
Thumbs up
Oh yeah...What about this idea I had. I am going to run some dekron tubing from A/C duct to the bottle!!! Tap a hole into duct, plumb dekron into it with fitting, run it nice and hidden to bottle, run dekron under blanket and VOILA...You have heard of bottle heaters, How about a bottle cooler!!!! Also good for going to get it filled. I am toying with the idea and would like your input!!!
Later
1989 Formula 350
Old Aug 23, 2002 | 09:45 AM
gb95zconv's Avatar
Post
I think the 1st thing you need to do is get that pressure gauge installed and see if excess pressure is indeed your problem. If you silinoids are older ones you may want to consider getten a couple of new ones.
Greg
95 Z28 conv M6
Georgia F-Body Association
Stage 1 heads, 1.6rr, Meziere WP
lt4 hot cam,lt4 timing chain kit,52mm TB,
Hooker Headers, Pro 5 shifter,3.73s,
NX 150 progressive,
Self-tuned via Tunercat
Old Aug 23, 2002 | 07:14 PM
Dark Angel's Avatar
Post
I have a black Z28 in south Texas, I have been leaving the bottle in the car and it gets hot as hell in the car. My pressure isn't usually anywhere near 1100 PSI. Once I open the bottle and purge it it usually around 1000, so yep get that gauge hooked up and find out if the pressure is high.
Old Aug 25, 2002 | 12:10 PM
Red face
WEll I put the guage on yesterday(at about 2:00 P.M. HOT!!!) and my suspicions were proven. My bottle pressure was at 1400 PSI!!! Now....Without using a damp towel, How would you go about cooling bottle or keeping by bottle cool without moving from location(back glass).
Thanks for all your help and my A/C idea did not work
Later
1989 Formula 350
Old Aug 25, 2002 | 02:49 PM
NVMYZ28's Avatar
Post
Why waste time/effort in trying to cool the bottle down if your going to leave it sitting in direct sunlight?
First thing id do is move the bottle....... I never have over pressure problems with mine.......
Jeff C - Utah
1994 383 Z28 M6
Bored, Stroked, Splayed, and Sprayed!
www.nvmyz28.com
Utah F-body Assoc.
Old Aug 28, 2002 | 11:34 AM
phil46y's Avatar
Post
I have my bottle mounted in the T-Top area and have it wrapped with a towel. Before I leave to go to work I take 2 of those frozen Blue Ice bottles out of the freezer and throw them in a wally world bag. When I get to work I pop open the hatch and lay the bag with the Blue Ice in it on top of the towel wrapped around my bottle, then I cover them with a heavy beach towel folded up just big enough to cover the bottle and bag of blue ice.
Usually when I get off work my bottle pressure is still under 1100,,,,,,,,and the temp inside the car is hot enough you wouldn't keep your hand on the Hurst T handle any longer than it takes to shift.
Old Aug 28, 2002 | 04:18 PM
Question
Well now that the gauge is on...I tried to hit it at 1000 PSI....Not Good..Started to jerk a little then a backfire!!!!! I was like WHOA. The next morning looked at pressure and it was at 700 PSI. Hit it and pulled as usual. I guess the max you can go with the NOS kit is 950 (as stated in the booklet).
Later
1989 Formula 350
Quickss96
Jan 29, 2016 05:56 PM
whitehooptie
Aug 17, 2015 08:35 AM
weedog
Aug 15, 2015 08:23 PM
Chris Ja
Sep 4, 2002 09:42 AM
