correct injector size?
I was wondering if I could get away with the stock 24lb injectors or do I have to upgrade to be safe. I have not run the nitrous yet (going to do a 150 wet shot). My mods are listed here: www.fbody.com/members/blueta/index.htm Also I'm going to be using a window switch. I have not watched the tach, but if I set it to go on at 3k will it spray in all gears even if it shifts and goes back to an rpm higher then that(like will it go on at 3200 if that's where it ends up when it shifts)? I don't want to sound like an idiot, but was just wondering. Thanks.
Jul 4, 2005 05:00 PM
