fuel system capabilities.
Old Aug 26, 2002 | 12:57 PM
dougg01's Avatar
Post fuel system capabilities.
What can the factory lines support...? We're running a mild 355 with the Hot cam, heads, etc and 24lb/hr SVOs. We also shoot a 150 wet shot off the schraeder valve. The pump isn't an issue. We shift around 6,100rpm.
So, how much of a shot will the factory lines support before the needed volume becomes an issue...?
Next year we are stepping up the shot and creating our own fuel system just for that so going to the expense and hassle of a fuel line upgrade from the tank doesn't appeal to me.
Tell me what the limits are, both statistical and what you've actually seen.
Old Aug 26, 2002 | 01:07 PM
2094you's Avatar
Post
the lines wont be a prob.... i plain on hitting 200 shot when i can fix my stupid problem
Old Aug 26, 2002 | 01:55 PM
dougg01's Avatar
Post
Oh, I know the lines shouldn't be a problem up to about 200-225hp shot and maybe 400rwhp on motor (both at the same time), but I want to know the limits. When will be be in an area of concern...? I don't want to run this puppy lean.
Plus, we're swapping to the CC306 this winter. That will change things a bit.
Old Aug 26, 2002 | 09:32 PM
gb95zconv's Avatar
Post
What kind of pump are you running?
Greg
95 Z28 conv M6
Georgia F-Body Association
Stage 1 heads, 1.6rr, Meziere WP
lt4 hot cam,lt4 timing chain kit,52mm TB,
Hooker Headers, Pro 5 shifter,3.73s,
NX 150 progressive,
Self-tuned via Tunercat
Old Aug 27, 2002 | 08:53 AM
dougg01's Avatar
Post
Walbro in-tank.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95maroboi
Jun 7, 2015 12:18 PM
Jul 4, 2005 05:00 PM
